Results 1 to 3 of 3
Thread: Battery Hold-Down
    Narre Warren South
    Battery Hold-Down
    A number of my Land Rovers are missing the battery hold down.
    I've looked at the hold down frame that came with one of them and decided I need to get some small steel angle and make a copy. Problem is that I can't get any steel angle small enough.
    Looking at the existing frame it's more like sheet steel bent at 90 degrees with a decent radiius.
    It's been in the back of my mind for some time but I hadn't found the material I needed. Then the other day I had a couple of doors that were given to me which I de-skinned and was about to throw the frames away because the bottoms were rusted out but there across the centre of the door was the steel section I was looking for.....
    When this is cut from the door frame and slit into two it is an exact match for the hold down frame material.
    Original painted black and a 'cut from a door' replica awaiting paint.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2015
    Southern Adelaide
    The battery box and battery hold down on Wombat shows her ancestry. There is a steel base welded to the chassis - obviously factory. There's a shallow surround bolted to this (about 1" high maybe), obviously factory.
    When unbolting that surround, one bolt sheered off and when I'd knocked the stub out, I found a spanner rusted to the head of the bolt
    Then there was the tie-down, 'tie' being the operative word because it was a length of hemp rope
    Yup, she was a farmer's ute.
    Sorry I can't help with your problem Grommit.
    Nov 2014
    G'day All,
    Over the last 43 years had to repair the battery hold down 2 times. So decided to make one out of 25x25x6mm angle and TIG welded it up. An exact replica of the original. That was 15 years ago and no further problems.
    Chris
