I recently fitted one of these to fix a UHF at work.
Trim the inner wire to length and fold the outer wire over the black sheath.
Slip it in the and screw the unit onto to give the outer wire a good contact, solder the inner to the tip.
Have a look at inside your base and see if the same system applies.
