Thread: D3 4.0L v6 Horn not working
    May 2013
    Bayside, Melbourne
    Hi Chaps
    My horn doesn't seem to be working, can't seem to find anything on the fuses, wiring etc (might be user error here!)
    Any ideas on where i should be looking? Might need a picture as well cause I can't find any diagrams!!
    Stevie
    Williams West Aust
    Any other steering wheel issues to match,ie faulty cruise control or audio if fitted???? If so in could be the "clockwork" spring that allows the electrical connection between steering wheel and shaft.
    Can you make the alarm sound??? Would rule out a fault with the horns,assuming the same ones are used for the security.
    GOODLUCK
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Feb 2013
    Wamuran, Qld
    Horn not working?
    Tried Viagra?
    Sorry.
    Ron
    2013 D4 SDV6 SE
    May 2013
    Bayside, Melbourne
    Quote Originally Posted by RHS58 View Post
    Horn not working?
    Tried Viagra?
    Sorry.
    Was waiting for that
    May 2013
    Bayside, Melbourne
    GOODLUCK
    Andrew
    Thanks Andy, I did try the alam. Also took the grill off and it seems I've only got one horn (steady chaps )
    Ended up being the fuse, however the other things were tried while SWMBO was out buying the fuse
