Results 1 to 10 of 11
Thread: wheel alignment
    Jul 2012
    central coast
    wheel alignment
    hi everyone.
    I live on the central coast of nsw,can anyone recommend a good provider of a wheel alignment as when I do the lower control arms I want/need this to be done correctly.Can be up Newcastle way not Sydney.Cheers
    boardrider
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by boardrider View Post
    hi everyone.
    boardrider
    There's a dealer in Newcastle area - Gateshead I think. Give them a call and see if they do it. Probably not and they may then recommend who they use. I asked my service manager at my dealer in Sydney to do a wheel alignment recently when I had my car in for service. He told me that they used the local Bob Jane store and advised me to take it there instead of waiting for them to do it as it would be cheaper for me and save me time. Gave me the name of their contact. Just remember about tight tolerance mode when you get it done. Also there was a recent thread about the advisability of changing a couple of bolts when you get a wheel alignment done. Couldn't find it but maybe someone else could chip in about it.
    Martin
    Found the thread I was talking about. May or may not be an issue for you.
    http://www.aulro.com/afvb/d3-d4-rrs/...t-snapped.html
    Last edited by letherm; 1st September 2015 at 11:25 AM. Reason: To add link to a previous thread.
    Jul 2012
    central coast
    WHEEL ALIGNMENT
    just thought I could ask again.there has been 116 views and only 1 reply so far. I would like to get a recommendation of someone who can do the alignment in the correct way.i will try Newcastle area also.Hope someone reads this and could help out
    boardrider
    Nov 2014
    Kariong NSW
    Wheel Alignment in Newy
    You could have a chat with All4x4 in Kotara..they tend to do a lot of LR servicing. They may do in house, or at OK East point you to someone
    D4 / e-diff / ECU upgrade
    FL2 TD4 SE
    LuvDisco Guest
    wheel alignment
    boardrider
    You have picked a hard one - I have been there and had no success finding a tyre shop that also had the decommissioning programme . I ended up going back to Bne from NNSW - and ran the risk of scrubbing a tyre - good luck with that. What I found was any of them can give it a go - however best to head to a 'dealer' as soon as to get the alignment done properly !
    Jul 2012
    central coast
    hi, I have booked in with Allfourx4 . I tried them b4 I saw the heads up but thanks.They set to TTM and then take to get the alignment done.I am going this Monday.Hope it works well.If all good I will be taking back once I do the lower control arms.Thanks for the comments
    boardrider
    Nov 2014
    Kariong NSW
    All4x4
    Let me know haow you get on
    D4 SDV6, e-diff, ECU upgrade, Xenon's, Rear air Garmin TX 3345
    FL2 TD4 SE
    Jul 2012
    central coast
    wheel alignment
    Dcinet.
    had the wheel alignment done today.
    result. the figures they gave me on the print out showed quite a difference.
    driving back to the coast the steering wheel was not centered, showing a little right hand down,seems a bit strange as it was level and straight b4 .In all fairness it may well be the lower control arm bushes being a bit suss.I will put up with it till I do my LCA then get the alignment redone,then I will know for sure All up it cost $137.50 which included them setting to TTM taking the car to get aligned then resetting the TTM.
    CHEERS
    boardrider
    dazray Guest
    Had a new set of tyres fitted and a wheel alignment at O'neills Warners Bay (Newcastle) today. What I liked about them was they are good price wise and did a really good job on my other car when they did the tyres and alignment. When I asked about new tyres and alignment for the discovery, the first thing he said is that they need to be set to tight tolerance mode for a wheel alignment and they have the equipment to set tight tolerance mode themselves. I told him I can set tight tolerance myself with my Nanocom Evolution. The wheel alignment cost me $75 with me setting tight tolerance mode. He said they normally charge $65 to set to Tight Tolerance, so that would make it $140 with them setting it for you.
    Steering wheel was the same as when I dropped it off (centred).
    Brisbane,some of the time.
    Good to see they put it in TTM.
    A lot of tyre shops around here just run them on the ramps and then leave them idling with a door open,doesn't sound right to me.
