Thread: Distributor Bracket
    May 2011
    Warrandyte, VIC
    Distributor Bracket
    Hey,
    Is there a bracket between the distributor and the engine block? There are 3 threaded holes in the block where the distributor fits into the engine block, but I don't seem to have the bracket (or hardware).
    Can someone post a pic? Would anyone have a spare bracket?
    Tibbsy
    1960 SWB Series 2 UTE
    1963 LWB Series 2a UTE
    Irymple, Victoria, Australia
    Do you mean theses three holes around where the distributor drops into place?
    If so there is a triangular shaped alloy plate that the distributor clamp bolts onto and the distributor can then be rotated to adjust the ignition timing.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Oct 2014
    Northern NSW.Australia
    Hi Mick,
    My engine gasket set came with a paper and alloy triangular gasket.
    Which should I use
    whitehillbilly
    May 2015
    Southern Adelaide
    I pulled my dizzy off the other day, not realising it had that triangular base, and it had the paper gasket (by 'paper', it was a normal gasket). I put it straight back on so I don't know if it had both.
    May 2011
    Warrandyte, VIC
    Mick,
    Thanks that is the part I'm looking for!! Great pick too, now I just have to find one.
    Tibbsy
    Quote Originally Posted by whitehillbilly64 View Post
    Hi Mick,
    Which should I use
    whitehillbilly
    The paper one does the job Billy.
    I am not certain but I think the alloy one may be for the diesel engine.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    May 2011
    Warrandyte, VIC
    Does anyone know the part number for this alloy plate?
    Jan 2014
    Googong
    Mick
    I think it is part # 247672 - 'adaptor for distributor'.
    Nic
    Oct 2014
    Thanks for the replies.
    whitehillbillies
    Wazzaorange Guest
    I have a different plate?
    I am having some issues with the plate I have. I have one with a dome underneath?. Not the plate seen in the picture. As my plate is damaged I have located another one ( same as the picture) but now my distributor will not fit? The distributor is too long it seems?
    Wrong distributor or wrong bracket? Any suggestions?..
    Cheers wazza
