Firstly, what radiator is it using? If using the original Land Rover one it is almost unheard of not having to cut out a section from the front cross member. If using a thin Holden radiator, you'll likely find it has overheating problems.
The bellhousing is not a great issue, the gearset inside an 86" box is essentially the same as the gearset in later boxes up to suffix A in series IIa.
IMHO the easiest fix would be to get a good 2 1/4litre Land Rover engine off anything up to SIII. It fits within the same manufacturer/series and capacity rules so only needs a blue slip certificate. A Holden even though a similar capacity (in some cases) is outside the same manufacturer rule and needs an engineer's certificate at a much greater cost.
Getting a good engine is the issue. But Landy 4 cyl seem to go for ages.
Diana
