Results 1 to 10 of 13
Thread: Engine and gearbox out
    May 2015
    Southern Adelaide
    I've put this in the general section in the possibly mistaken belief that the process is more or less the same for all the series.
    I'll be pulling the motor AND the gearbox out of Wombat (then suspension and axles etc, hence both of them now).
    Is there a recommended/sensible/least idiotic procedure?
    I'm thinking
    Engine out.
    Tail shaft off.
    Gearbox out.
    But would it be easier to go
    Tail shaft
    Gearbox
    Engine?
    Am I best served removing the firewall first? It's only in place now so I can steer the brute pushing her in and out of the shed.
    I've got a heavy duty mechanical bottle jack (off a truck), so I can prop up the back of the engine or front of the gearbox or whatever if needed while doing other stuff - it's not going to sag like a hydraulic jack and is as stable as many axle stands.
    Also, the engine head isn't bolted on and there are no studs in the block and I've got a horrid feeling I don't have any studs so the motor will be removed without the head (less weight, less size) and with straps (tow rope probably) slung underneath... at least that's the plan. I'm leery of trying to screw bolts into the block just to lift her.
    Be more convenient (and cheaper) if I don't have to hire an engine crane either so I'm interested in suggestions there, though not overly passionate about the idea, it mainly means I don't have to be organised and get everything done in a day. Rented house so I'm not going to go hanging things from the shed rafters in case I pull it down.
    East-South-East Girt-By-Sea
    1.20 MB
    When we were lazy or short of time, we used to take the prop shafts off and remove the transfer off the back of the gearbox and drop that out the bottom. That then allowed the gearbox to be taken off the engine and also dropped out the bottom and then the engine out the front.
    However if you're doing a complete re-build take all the floor panels and seat box out and lift the whole transmission up and out from the passengers side.
    Engine still comes out the front.
    May 2015
    Southern Adelaide
    I'm glad I asked, I didn't realise the transfer could be separated from the gearbox like that.
    She's been stripped down to chassis and firewall so no floors or anything to get in the way
    I was going to drag her out to clean her up first but maybe I could do that after pulling the motor and gearbox. It'd leave the motor and box covered in years of crud but they'd need to be cleaned again anyway.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Hi crackers, ive just done the same thing in my driveway ( rented house too ) here at home. Just cleaned the chassis today and the underside of the tub. 48 yrs of crud has been cleaned off. Now the job begins.....ohhhh so much fun ahead for both of us...lol
    Cheers Rod
    Sent from my GT-P5110 using AULRO mobile app
    99.87 MB
    From there I would most definitely lift the firewall and then take the engine and gearbox out as a single unit.
    Slunnie
    May 2015
    Southern Adelaide
    Quote Originally Posted by 67hardtop View Post
    Cheers Rod
    I see you're at Blair Athol - wouldn't be scarred by a disreputable visitor would you?
    Apr 2014
    Hi crackers, Nah. Very quiet street. Chassis blocked in by s3 landy. Welcome to come check it out if u want. Call me if u wanna come visit. 0419847861. Be prepared to talk lots of land rover language...lol
    May 2015
    Southern Adelaide
    I'd definitely need a crane to do engine and gearbox as one unit, then would need to be able to store them as a unit.
    Maybe push her out for the big wash. Back in the shed. Pull the firewall (and steering column seeing they're bolted together). Then follow Lotz-A-Landies' routine to get the gearbox and engine out.
    I think there's no doubt I can get the gearbox out with just jacks and my son.
    I reckon we can do the motor too seeing it's effectively a short motor (just lift the head off, it ain't bolted on) and don't have to lift it too far to clear the chassis - if that proves too silly, then I'd organise a crane.
    Of course, I'd have to book my son - his fiance seems to think she's got a call on his time
    Apr 2014
    Take it from me, ( im a mechanic ), crackers, use a crane. Gbox n transfer case pretty heavy, as is the motor. U dont wanna do ur back or crush any fingers. Things have a habit of falling of jacks.
    Cheers Rod
    99.87 MB
    Same. I ended up buying a crane and have used it more than enough to justify it. Every time engines, axles, firewalls etc etc need to be moved, lifted etc. They are handy and its a very safe operating procedure to use when doing heavy lifting, especially if you need to get under the vehicle. I've never had a motor that just happened to drop into the right place. they all go in and need shoving and pulling and twisting and tilting and lifting again and lowering just for the engine mounts - thats not to mention trying to not smash or dent everything else around it.
    Actually, I couldn't lift an engine and barely a gearbox.
    Slunnie
