Results 1 to 10 of 18
Thread: Parts washers
    Geelong, VIC
    Parts washers
    I've had enough of Supercheap degreaser cans, paintbrushes and dirty plastic tubs - so finally going to build or buy a parts washer.
    I'm keen to give a water based cleaner a try as I'm not keen on having a large volume of solvent in an shed that also I weld/grind in.
    Reading a few older threads here the "Simple Green" concentrate seems to have positive reviews. Any other likely contenders?
    Size wise, the 90L washers (78x55x30cm) would fit most things I'm likely to clean (mainly just general landy parts). Is there any compelling reason to get a smaller/larger size?
    Looks like I can buy a new 90L one for about $200 upwards. Any particular particular brands/features to look out for?
    Would I end up with a better result for a similar cost by just making something up myself?
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Hint: Want some degreasing liquid cheap?
    Drive to local "Car Bath / Wash" - remove empty 10lt container from vehicle.
    Select "Degreaser"
    Insert $2.00
    Fill container
    Geelong, VIC
    Awesome - would never have come up with that myself
    Steve
    Mar 2010
    x
    Select "Degreaser"
    Insert $2.00
    Fill container
    That degreaser is usually watered down to within an inch of its life.
    May 2014
    Tamworth NSW
    Thought of doing this:
    [ame]https://youtu.be/URo31_aTHUk[/ame]
    Great youtube channel, if you are that way inclined. Bloke really knows his stuff
    -Mitch
    'El Burro' 2012 Defender 90.
    Aug 2012
    Logan,Queensland
    I recently purchased this one.
    A368 | APW-76 Auto Parts Washer - Floor Model | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
    Quite good value. well made and sturdy.
    It uses a water based solvent.
    5 litres of concentrate for $40 with 40 litres of water.
    The light oils (p/s fluid) float on top of the water and I had to skim it off.
    Heavier grit and stuff falls to the bottom.
    The inlet for the pump is probably a 8cm x 8cm filter that sits about 2.5cm from the bottom of the tank.
    Had to top it up with 5 litres of supercheap degreaser after 2 months as the cleaning strength was fading.
    Had to add a stool to sit on, as it is a little too low and hard on the back after 10 minutes or so.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Geelong, VIC
    Quote Originally Posted by Toxic_Avenger View Post
    Interesting - a DIY twist on the old engine wash gun.
    White spirit is nice as it dries off well. We used to use it years ago to wash down aircraft piston engines, but not sure I'd want to atomise a couple of litres in my shed (which is also where my compressor is).
    I also noticed that there was nothing he cleaned that was what I'd term "landy dirty". In my experience combining compressed air and dirty parts is a recipe for crap everywhere in the nearby vicinity.
    Outside, for something like an engine block I can see it being great, but I'm not convinced for general parts cleaning inside a building.
    Steve
    Feb 2013
    Ballarat,Vic,Aus
    I purchased one of the chinese parts cleaners quite a few years ago. I've put it out in a crappy garden shed beside the shed (with the compressor). YOu know, I find I rarely if ever use it. You see the $2.00 export degreaser tins and pressure washer are far, far, far more effective
    seeya
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    I have one of these...
    https://www.kincrome.com.au/parts-washer-12-litre
    Perfect for small components..
    For larger - I agree with Double Chevron... Degreaser and Karcher!
    Feb 2013
    Ballarat,Vic,Aus
    I grabbed the free standing one ... It appears they are still sold unchanged.
    20 Gallon Parts Washer ON Stand 240V Electric Pump | eBay
    I'm surprised how rarely I use it. The export degreaser cans are just so incredibly effective and cheap.
    seeya,
    shane L.
    Proper cars--
    Modern Junk:
