Results 1 to 10 of 29
Thread: Freewheeling hubs on a 6X6 perentie
    Hay Point
    Anyone know if the 24 spline series 3 freewheelers will fit on the Salisbury axles. I am looking at fitting them to the rear axle on mine after I put the detroit lockers in. If they will fit it will save the rear axle from windmilling all the time.
    Cheers......Brian
    1985 110 V8 County
    No. Five bolt vs six bolt drive flanges.
    But believe it or not, free wheel hubs do exist for coil sprung Landrovers, and would fit. Presumably made for the earliest 110s that had selectable four wheel drive optional. And I have seen them offered for sale, although not recently, but a poke around might find a pair.
    Kingston, Tassie, OZ.
    Hi brian ashcrofts do a kit to suit early 110 so should be right for your axle flanges.
    http://www.ashcroft-transmissions.co...-time-kit.html
    You'll only need the hub kits though.
    Jc
    Hay Point
    a
    Thanks John, JC has just come up with the link to them.
    Cheers......Brian
    1985 110 V8 County
    Hay Point
    Ashcroft Transmissions
    Jc
    Thanks JC, from that Ashcroft link it looks like they are AVM so possibly may be able to get them here. With our low dollar and high postage cost from the UK it's probably just as cheap to get them here. Have to make a few phone calls!
    Cheers......Brian
    1985 110 V8 County
    Feb 2011
    Rileys Hill
    Rear hubs AVM. Paul.
    Hay Point
    Quote Originally Posted by powerband View Post
    Thanks Paul, looks like AVM are the go. Had any problems with them? I remember oil leakage was always a problem when I had them on Series vehicles years ago but I think they were Selectro brand.
    Cheers......Brian
    1985 110 V8 County
    Quote Originally Posted by Bearman View Post
    I think you still need the flanges that are made by ashcrofts to bolt the avm hubs to.
    Jc
    Hay Point
    I thought they would bolt straight on where the drive flanges go? Found an AVM kit number so will ring and find out.
    Cheers......Brian
    1985 110 V8 County
    Ah yes well that could be so. Make it a lot easier.
