Sounds like the common issue of oil pooling in the turbo. This is normally fixed if mentioned while under warranty by installing a drain. Yours may not have been done.
 Fossicker
						Fossicker
						Is it normal, and it seems to be only after pussy footing in traffic for a long time, on full throttle and only high revs, chugs out a fair amount of blue smoke?? After its "cleaned out" or "red line serviced", I dont have the problem until I have been sitting in traffic for a while.
2010 D4 3.0
How full is the oil on the dash check???
If overfilled any motor will burn the extra it cant deal with,ie too much oil splashing where it shouldnt.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
 Fossicker
						Fossicker
						If it's not overfull, have a read of these threads, should help.
Blue Smoke
http://www.aulro.com/afvb/d3-d4-rrs/...lue-smoke.html
Turbo drain pipe
http://www.aulro.com/afvb/d3-d4-rrs/...liability.html
Link to my D4 Build Thread
D3 2005 V8 Petrol
 ChatterBox
						ChatterBox
						Hi,
My first D4 had a DPF .... so no smoke at all.
My MY13 definitely does pump smoke under acceleration .... especially from idle. Most guys I know with D4s report the same ....
Have you sat behind a Nissan or Toyota, etc?
So what is normal and what isn't?
Is the smoke definitely blue?
 Fossicker
						Fossicker
						Hi,
Had the same peroblem on my D4 MY12. Took it to dealer who said they had a revised drain hose for this problem. Problem all fixed.
Cheers.
