I have the full length version on mine, and no sunroof. I travel fairly frequently between Kalgoorlie & Perth with no load on the roofrack.
Yes, it does make more noise than the vehicle did without the rack fitted, but not enough to annoy me. It is certainly no worse than other racks that I have had experience with in the past.
Mine is probably a bit worse than just a bare Frontrunner rack, as I have two additional items mounted underneath the platform. Between the two front legs is a 42" LED lightbar, and beneath the platform a little further back is a stainless steel top & aluminium frame camping table which slides in under the platform (it's an option offered by Frontrunner).
Mine has a "wind deflector" under the front of the platform (supplied with the rack from new). I don't really know how effective this is at reducing wind noise, as I have never run without it fitted - however I have been told that the rack will be very noisy without it.
I would say that the main cause of wind noise with this model rack is the fact that the platform rails run across the vehicle / rack. I have seen pictures of a similar platform offered by another supplier (sorry, can't remember who) where the platform rails run length-wise along the rack. I would expect this to be a quieter option.
From my experience though, I can't fault the Frontrunner rack. Very solid bit of gear and easy to mount attachments both above and beneath the platform. We have travelled a lot with ours loaded and never an issue - and I have used it on occasion to cart some reasonably heavy loads of building materials here in town. The one smart addition that I have made to the vehicle since installing the rack has been the ladder on the rear tailgate - this has made life a lot easier when loading / unloading the rack.
One tip though - if the roof on your vehicle could do with a good wash and polish, do it before fitting the rack. There's not a lot of room to get your hand and a polishing cloth in there once the rack is on the vehicle.
				 D4  2.7litre
D4  2.7litre
