Page 1 of 8 123 ... LastLast
Results 1 to 10 of 79
Thread: Head Gasket replacement
    Feb 2013
    Gosford, NSW, Australia
    Question Head Gasket replacement
    Hi
    I have the dreaded coolant leak happening, plus a small oil leak though i'm not sure where that is coming from.
    Going through some of the other threads, I have come up with this list of parts and I am looking for comments, good or bad !
    ARP Stud Kit; ARP-157-4301
    Elring head gaskets; (LR #LVB500030)
    Payen Valley Gasket; JB894 (#LR AJM693)
    Valley gasket end seals;
    Trumpet base Gasket;
    Steel Exhaust manifold gaskets
    Rocker Cover Gaskets;
    Valve stem seals;
    Injector seals;
    O-Rings;
    Coolant hoses;
    Pushrods; Adjustable perhaps, or shims to set preload for rockers
    Most of this can be obtained in a good VRS set, then it seems you just need to buy the Payen Gasket
    Steve
    May 2010
    Mindarie, Western Australia
    Steve
    Another item would be a long extension for tensioning up the head bolts. They are incredibly tight. I used a 1.5m extension on the end of the spanner
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    May 2003
    On The Road
    so little time, so much to say,,
    do your research. read V8 rebuild threads.
    studs are good
    glue your rocker cover gaskets,
    glue your valley gaskets.
    I dont have a good opinion of any brand composite gasket.
    Head gasket torque is a "cross your fingers" moment.
    Feb 2013
    Quote Originally Posted by mtb_gary View Post
    Steve
    Mate
    I large breaker bar is a part of my weaponry already, though i may have to get another length of water pipe for extra leverage !
    Steve
    Feb 2013
    studs are good
    Mate
    Do you prefer the stainless head gaskets ? Most seem to prefer the composite ones.
    I have been reading heaps, the threads on here as well as the Paul P38a page.
    When you say glue the gaskets do you mean with something like Permatex Hylomar?
    Jul 2014
    Where is the dreaded coolant leak Steve?...engine rear?..on bell housing?
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Feb 2013
    Quote Originally Posted by daf11e View Post
    Mate,
    Rear of the engine you can see it running down the side of the engine
    Jul 2014
    Thanks mate , reason I asked is I had a coolant leak at the rear for a while and after checking everything was 90% sure it was like Paul 's write up with head gasket leak rear and onto starter motor. You wouldn't believe since I had the coolant fire and replaced the top hose there is no more coolant leak at rear or loss. Don't know yet if I've dodged a bullet but we'll see....good luck with yours!
    1974 xj6l jaguar
    Quote Originally Posted by TheTree View Post
    I used that ARP stud kit.
    Head gaskets - maybe Cometic MLS. That's what i used. They are pricey, though.
    I used the composite exhaust manifold gaskets but you may recall that Jilden mentioned he's had failures with them. My thanks to Scouse...
    May 2003
    On The Road
    Mate
    Multi layer steel, (MLS),, just do it.
    I used 40thou. wish I'd used 20 now,,
    I did the studs to 100lbs, you could go less,,,,
    but I wouldnt.
    lots of informed engine builders here to help with glueing gaskets,, any/everything that keeps fluids in or out needs glueing, whether its a spray hylomar for the MLS or a silicone for the valley,, its cheap insurance.
