Thread: Fuel gauge issue
    cairns
    Question Fuel gauge issue
    My 2002 defender has developed an issue with the fuel gauge reading.
    Sometimes when I turn on the ignition the reading is incorrect, usually lower.
    This has been gradually getting worse but doesn't happen every time and when it does read correctly from startup it stays that way.
    Any ideas would be appreciated.
    Paul.
    Paul.
    77 series3 (sold)
    95 300Tdi Ute (sold)
    2003 XTREME Td5
    I thought I was wrong once, but I was mistaken.
    Bearman's Avatar
    Hay Point
    A common problem is earths on the gauges Paul. They vibrate loose and give inconsistent readings like you are getting. Check them all as they are interconnected.
    Cheers......Brian
    1985 110 V8 County
    cairns
    Quote Originally Posted by Bearman View Post
    Thanks for that,
    so would the earth in question be at the pump end or the gauge end?
    Or both?
    Paul.
    Paul.
    77 series3 (sold)
    2003 XTREME Td5
    JDNSW's Avatar
    Could be either, but more likely at the gauge end. Try switching the instrument lights on and off (remembering to wait for the gauge to change - response is slow) - if this affects the reading, it is certainly at the gauge end. Usually also affects the temperature gauge, but this depends on exactly where the loose connection is.
    Dec 2010
    cairns
    earths
    had the same on my 98 110 tightened all the earths on the gauges cleaned all ones I could find on the body seemed to fix it cheers.
