Results 1 to 10 of 17
Thread: 86" brake upgrade options
    Aug 2011
    When I upgraded the brakes on my S2 SWB I simply used a dual circuit servo pedal assembly with the larger diameter twin leading shoe backplates etc. However the outrigger mounted master cylinder on the 86" does not look like this path is viable. It does look like I can get an inline servo squeezed in to the area under the air filter, but that reduces pedal effort rather than increasing braking efficiency.
    I'm not really interested in going to the effort and expense of a disc conversion, but I'd like more braking than the 10" single leading shoes provide. I can probably gain a bit with new drums and Mintex (soft) shoes, but are there any other options?
    Before I undertake too much research, I thought I'd ask if there is an accepted approach to upgrading S1 (86") brakes? A search indicates I can fit a S2 master cylinder, but that doesn't seem to be an upgrade (more a use of available parts) as the braking system remains 10" 1LS.
    I'm assuming that the S1 master cylinder is the wrong bore to properly activate 2LS wheel cylinders, so what options if any exist?
    Irymple, Victoria, Australia
    I have VH44 in line booster in the right hand guard area of my SWB series 3 and it fits neatly.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    East-South-East Girt-By-Sea
    1.20 MB
    Hi Warb
    In-line and pedal mounted boosters only reduce the effort your boot needs to apply a certain pressure to the hydraulics.
    I know of one person who fitted the pedal boxes from an SIII onto an S1 88", but can not remember if he used pedal mounted booster type. That would be your easiest option if you want to go to dual circuit and larger 11" brakes. You would however have to modify your Rt inner mudguard.
    I do know people have fitted SII/SIIa master cylinders with the two bolt flange onto the outriggers and you may well find a dual circuit cylinder to do the same.
    In relation to in-line boosters, the recommendation is that they should not be mounted higher than the master cylinder to prevent air locks by bubbles rising to the highest point. This can partially be solved by using a booster that has a bleed nipple. It was common for the in-line booster to be mounted behind the gearbox.
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    Hi Mick
    That's a great place in the SIII and even the SII/SIIa however that area is different in the S1 and a little more difficult, also see my comment about the height of the booster in relation to master cylinders on the chassis under the floor in S1.
    Aug 2011
    In-line and pedal mounted boosters only reduce the effort your boot needs to apply a certain pressure to the hydraulics....
    Both very true!
    With regard to the pedal box, I have never inspected an 88" S1 but from your comment I assume it also has the under-floor master cylinder. So if the firewall is more or less the same, then if the pedal-box style brakes can be made to fit the 88" the same should apply to the 86".....? My concern would be whether the firewall, which was never intended to have such a pedal box mounted on it, might be less strong than the S2 version in that area? I shall have to do some investigating!
    I'll also have to have a quick check to see if the dual circuit master cylinder might fit under the floor, and whether a remote reservoir could be fitted!
    Edit:
    I forgot to say that when I discussed the positioning of the servo with Terry at Hydroboost, he mentioned a couple of things. Firstly was that having the servo higher than the master cylinder could cause the first push of the pedal to be "long", which I assumed was the same issue as mentioned by Lotz-A-Landies above. Secondly was the requirement to fit a remote breather, sealed to the servo air inlet, if the servo is in a low or exposed position. The breather is sealed to the servo with mastic, and the attached hose is routed up to "clean" air higher in the engine bay.
    1.20 MB
    Hi Warb
    Some reinforcing of the footwell in the S1 would be required, but even in the S2/S3 the reinforcing is merely another piece of sheet metal about 2mm applied to the top.
    You could probably salvage the part off a later dead firewall or cut one out of sheet and weld or glue on onto your S1 footwell.
    Some boosters are made for an extended breather, the Clayton Dewandre used OEM on UK built SIIa and SIIb forward controls, and the VH44 has similar.
    It was basically a thin disk with a pipe and hose. The disk fitted underneath the standard dust filter spring clip and the hose finished up on the firewall by the steering column.
    Aug 2011
    The VH44 is the unit that Hydroboost recommend, and the one that I am familiar with as it is the one used for Mini's.
    However I am now wondering whether the S2 style pedal box is a better option, as I have all the parts to hand and making up suitable reinforcement for the firewall is easy enough. It would also allow me to upgrade to a complete LWB brake system with servo and dual circuits etc. My only slight reservation is that this is such an original vehicle (if we ignore the Holden motor currently fitted!) that "cutting" seems sacrilegious, but on the other hand it's only an 86" and not really that rare. If upgrading the brakes allows it to continue to be used safely on modern roads, that can't be bad..?
    Tomorrow I shall have a serious measure up and see what a pedal box installation involves!
    May 2015
    Southern Adelaide
    Are you building a museum piece or a vehicle you want to drive?
    I wouldn't sweat on the modifications. I say this because you obviously want better brakes so fit them and feel comfortable. To satisfy the quest for originality at a later date, make sure that anything you do can be reversed.
    Narre Warren South
    Less 86" made than 80".
    Land Rover FAQ - History, Production, Sales - Production Data
    I'm running a Series I on the original braking system and it does take some 'forward planning'.
    Personally I'd try not to make any non-reversible changes but I understand why you might want better brakes.
    You suggested new drums & softer linings, why not see whether these make a big difference before cutting anything. If you do upgrade further at least you'll know the drums & shoes are as good as you'll get.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Aug 2011
    Quote Originally Posted by crackers View Post
    Normally it wouldn't worry me in the slightest, but then normally by the time I've steam cleaned a vehicle I've found several holes in the chassis and I'm already resigned to doing some welding. This vehicle has a perfect chassis and only one tiny hole in the firewall (now fixed). It has been stored in a shed, been used/loved for most of its life by 3 generations of one family and could be rego'd in QLD with zero work. That's the only reason for the slight hesitation! But I'm over that now, and tomorrow I'll be measuring it up for improvements! If I can get a dual circuit servo'd pedal box to fit, that's what it will have!
    Aug 2011
    Quote Originally Posted by gromit View Post
    I seem to remember there were only about 1500 RHD CKD S1's made in 1956, but my collection of random LR remains from local farms means I have 3 86" but only 1 80" (and one tray back LWB S1). So 80" seems rarer to me!
    The problem with replacing the existing drums and shoes is that if I can get the later pedal box to fit, then it would seem sensible to also include the bigger drums and 2LS front brakes (I believe this was the very late S3 SWB configuration, though I could be wrong!), which nullifies any money spent on 10" parts. Otherwise I agree it would be a good plan!
