Results 1 to 8 of 8
Thread: Brakes on a 130 300tdi
    Nov 2008
    Bruthen, Eastern Vic.
    I have noticed that the brakes on my 95 300tdi 130 don't bite too well. I can't lock the wheels at all on gravel or bitumen. That can't be right.
    Pads and rotors were replaced by previous owner, I have done about 40k km on them. Don't know what brand they are.
    Pump vacuum is between 5 and 20 in Hg, depending on engine speed. Should be enough?
    Does anyone have any recommendations on pads? I don't mind dust or fast wear. I am very easy on brakes.
    The brake manufacturer websites are useless, they talk about things like "hybrid fusion and stealth technology" whatever that is....
    Terry
    80 109" 2.6 P ex Army GS, saved from the scrappie.
    95 300tdi 130 Single cab tray.
    2010 Guzzi 750
    Dec 2010
    cairns
    brakes
    sounds like a vacuum pump or booster problem if the pedal is hard after start up id be checking vacuum pump and booster,trw pads are ok cheers
    Oct 2007
    Wantabadgery, N.S.W.
    I use genuine pads after a mechanic fitted aftermarket and the screeching could be heard several suburbs away.
    Check the front of your booster for cracks around the mounting bolts. It's a common issue. The cure is a new booster, and if yours is cracked, you'll notice a big difference in braking performance when the new one goes on.
    Don.
    Nov 2008
    Thanks Don & Mudder, couple of things to check.
    Vacuum is 20 in Hg, I don't think a little plastic pump would do better than that.
    Genuine pads sounds like a good idea.
    Terry
    2010 Guzzi 750
    Torres Straits
    Check the booster near where the master bolts on. Very common for them to crack. Crack opens when peddle pressure applied which then leaks all your vacuum away. I assume you have checked the vacuum from the pump upstream of leak.
    Very common fault.
    Nov 2008
    Good call, maybe I had better check the vacuum with a tee in the line.
    Thanks.
    Terry
    2010 Guzzi 750
    Torres Straits
    A tee in the line and applying peddle pressure will open any hairline crack and leak off vacuum.
    S
    Nov 2008
    Problem is found - I think
    Vacuum direct connection to gauge 20 in Hg max
    Vacuum with gauge teed into line 8 in Hg max
    Won't hold vac with engine stopped.
    Can't see any cracks, might be the diaphragm
    Terry
    2010 Guzzi 750
