Results 1 to 9 of 9
Thread: Woodworking = VJ Router Bit
    Mar 2010
    Queensland
    12.97 MB
    Woodworking = Vee Jay Router Bit
    Hello All,
    Are there such things available as a router tool bit that will form a Vee Jay or VJ join?
    Instead of having the right-angle steps that fit flush like the tongue and groove floor boards the VJ boards have a 45 degree edge leading back from the tongue. A similar 45 degree angle is formed on the top part of the "groove". When two boards are placed next to each it forms a "V".
    Is there one router tool that will allow the VJ profile to be formed? Or does the tongue and groove have to be cut first and then have two passes made with a "V" router bit?
    The left image is VJ and the right one is T & G
    Kind Regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    HHmmm probably should have posted this message in this thread in the first place. Moderators cooeee!!!
    http://www.aulro.com/afvb/technical-...ml#post2433803
    Kind Regards
    Lionel
    Shepparton
    Have you had a look at Carbi tech or Carb I Tool? They would be your best bet.
    Oct 2007
    Wantabadgery, N.S.W.
    Nov 2014
    Kettering Tasmania
    Quote Originally Posted by Lionelgee View Post
    Hello All,
    Kind Regards
    Lionel
    Australian Tool Company makes one - cat no. RB-VJ4524-12
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by tonyf View Post
    Cheers Tony,
    Yes, that is the one that I was after. Thanks for the link.
    Kind Regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Thanks Moderators
    Hello Moderators,
    Thank you for moving my message. Much appreciated
    Kind Regards
    Lionel
    Shepparton
    Question - why do you want to create such a board when the boards can be bought that way?
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by crash View Post
    Hello Crash,
    Because of recycled timber that I want to use that did not come with a VJ profile.
    Kind Regards
    Lionel
