Results 1 to 4 of 4
Thread: Lubricants
    Feb 2013
    Ballarat,Vic,Aus
    Lubricants
    Hi Guys,
    a 92 Range Rover with borg warner transfer and slugomatic gearbox. I've just been changing all the oils. Other than the 3 billion pumps that "High Capicty" 1 litre oil pump required this was a really simple task.
    I was sure everything would be empty 'cos it doesn't drip at all ( bizzare ... a little wet underneath, but not a single drip under it ever). Anyway, everythng was at capacity except the transfer case that I just drained 2litres of stinky gearbox oil from .................................... I thought this was supposed to contain 1.7litres of ATF ?? That's what the manual says ??
    Do I need to go buy another bottle of gearbox oil, or is ATF ok to use in the borg warner transfer case
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Douglas Park, NSW
    The viscous transfers in the RRC were always ATF. I can only assume a workshop has not been aware that it's a viscous unit & stuck in what they normally use for Discos & older RRCs.
    Dec 2014
    FNQ
    Use a high quality synthetic ATF in the transfer case.
    Or neo synthetic Hi vis MVP ATF. (7wt) if you plan on doing a desert trip
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Mercguy View Post
    I'm hoping the transfer case or slugomatic gives up the ghost at sometime in the next 12months ................... This will give me the excuse to stick a proper gearbox with LT230 in there I've never liked slugomatics!
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
