Results 1 to 4 of 4
Thread: Lift Up Door Handle Operation
    Feb 2013
    Sunshine Coast
    Is it possible - with the lift up door handle mechanism as found on Perenties - for a passenger to get out, lock the door and then shut it so that it is still locked? How about on the early lift up handle 110s?
    My Perentie's locks don't seem to want to shut and lock, but that doesn't mean its meant to be that way!
    Jan 2012
    Yanchep Western Australia
    Quote Originally Posted by Dervish View Post
    Not to my knowledge. The only way to lock the door from the outside is with the key once the door is closed.
    Regards Warrick.
    "Any intelligent fool can make things bigger and more complex....It takes a touch of genius and a lot of courage to move in the opposite direction."
    Albert Einstein.
    in the wild New England, NSW
    Quote Originally Posted by wpalmo View Post
    Regards Warrick.
    Can be locked/unlocked from the inside with the lever (eg. if you have a soft-top or if the person exiting the driver's door does it)
    That is the way they are - same as the early 110s or late Series 3.
    Interestingly, this has been the case with most of the cars I have ever owned!
