Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Gearbox Oil
    Oct 2014
    Northern NSW.Australia
    Gearbox Oil
    What does everyone use, that is easy to get hold of ????
    Would this GL4 be ok for our Northern NSW/ SE Qld climate ????
    75W-80 Smooth Shift Manual Gearbox and Transaxle Oil - Nulon Products Australia
    Thanks.
    whitehillbilly
    it'll be fine
    Oct 2014
    Thanks Dave,
    would that be the same for the Fairey OD unit ????
    whitehillbilly
    Yes.
    Oct 2014
    Thanks John.
    Yes.
    concur.
    the stock Series any is a 2 oil machine. Engine oil (15/40wish) for the engine and 80/90 for everything else that has oil in it.
    Queensland
    GL4 or GL5
    I have been using GL5 for the past year or so.
    Now a supplier has found me a 75/90 GL4 which I have ordered and will do a drain and replace.
    What damage is likely to be seen with this use of a GL5?
    Does it pit the bronze sleeve and synchros or what?
    Will they disintegrate or will it take longer than a couple of years to see any negative affect?
    Oct 2014
    Hi 123Rover50.
    If you Google search, some say they have been using GL5 for years, in a series Land Rover, others say the chemicals attacks the bronze bushes.
    Yet there appears to be no clear evidence, to say that is so.
    Seems mostly hear say.
    I would like to hear from any members who have rebuilt 50 or so Land Rover gearboxes running GL5 for 5 years to tell us different.
    Anyway I like mineral oil, don't know why but always run it in my vehicles.
    So I intend to run, in my gearbox the closest I can get to the Original, cheap and local, and available.
    That being what I listed from the local auto shop. ( GL4 and they give me a good price )
    Look forward to the feed back.
    whitehillbilly
    Narre Warren South
    It seems to depend on what was used to give the GL5 oil it's extreme pressure characteristics. My local oil blender said that their GL5 should be OK but then suggested that they blend me some GL4.
    Taking that into account maybe some GL5's are OK and others may cause problems with bronze bushes etc. in older boxes/diffs.
    With that in mind why take the risk ?
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    the series box wont care. (especially not a II or IIA box)
    the diffs and tcase definitely wont.
    the biggest issue you're going to have with the "thinner" modern gear oils is keeping the stuff in the box.
    IF you need to you can even put cooking oil in to get you home.
