Results 1 to 10 of 30
Thread: Removing rusty/stuck core/Welch cup plugs
    Aug 2012
    One of mine is leaking (and I have the engine out), I've tried knocking one at an angle to get it moving and self tapers but it just pulled out with vice grips.
    Any suggestions please? I'm a bit nervous about applying heat as it started hissing!
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    normally just punch a hole in them with a hammer and screwdriver and lever them out
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2012
    Hmm, maybe it's the edges being rusted but I'm having no luck!
    Feb 2014
    Quote Originally Posted by Shakey View Post
    the bigger the problem the bigger the hammer.
    Old saying but true sometimes...
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Oct 2015
    Tasmania
    Get a big screwdriver, the bigger the better. Punch it through the plug (using a hammer) and lever against the block.
    Jan 2013
    Molesworth,Tasmania
    I'm about to do mine. Hope I don't have a similar struggle.
    Noticed you had a Caterham. That's the last place I lived in before I came out here. The showroom was still there c2000 but I think they made the cars elsewhere.
    cheers,
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Aug 2012
    I'm going to do the other 2 today so hopefully they will be easier. I ended up destroying the front one and pushing one side in, I could then squeeze if out the whole!
    They have a factory in Dartford too I think, but caterham was taken over by a new owner so it's probably all changed again!
    I usually use a large pin punch and the FBH, beat them at the edge till they either tilt or tear then pull them out while you;re at it dont forget all the screw in plugs and the little ones.
    the ones that seal the hole used to machine the cam usually never give trouble.
    Aug 2012
    Thanks, I'm rapidly learning you can generally hit things a lot harder than I think!
    May 2015
    Southern Adelaide
    It's a bit like knowing how tight to do up a nut... which is to do it up until it strips then back off a half turn
