i am getting a set for our Simpson trip, been advised to spend about $300 and stay off ebay
Thinking seriously about getting one of these for our 110 Puma. Anyone have experience or recommendations as to a particular brand? Some friends have the Tyredog one, seems to work pretty well. Any thoughts appreciated.
 Master
						Master
Have read of this recent thread, one of may on TPMS.
TPMS
In it I mentioned we have just fitted a SensaTyre set up to our Defender.
I'm watching the tow horse, Tvan plus 3 spares.
I used to sell the TyreDog units and still have my original 4 tyre unit.
I found that with the very short wheel valve stems (as per go carts, about 20mm long) the Tyredog unit did not mark wheels etc. Also my 4 wheel unit works fine on all my wheels, and when towing a trailer/camper I move my front sensors to trailer.
I use it as an alarm, and have never relied on the pressures indicated, although they have been pretty accurate. They have caught 2 punctures, one on trailer, one on vehicle, and alarmed when pressure dropped below 20lb, so I was able to repair or change tyre before it was destroyed etc.
4 Tyre units are now about $300 in Aus and $200 from Taiwan Ebay suppliers. eg: http://www.ebay.com.au/sch/tiffany28...&_trksid=p3692
6 tyre units have a transponder (to be mounted in rear of vehicle) to ensure signal reach to trailer.
Last edited by rrturboD; 22nd October 2015 at 10:08 AM. Reason: added ebay reference
Michael T
2011 L322 Range Rover 4.4 TDV8 Vogue
Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
Good tip about moving the front sensors for towing. Rear and trailer tyres are the ones you most commonly see shredded, and you've got half a chance of feeling something wrong on a front wheel.
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
 Master
						Master
						I bought a 4-set from Kroz Automation, Moorabbin before our last trip for $129.
Pressures are accurate when compared to Shell pre-set air stations.
Because the sensors are mounted externally, temperatures are not much use except for telling you the outside temperature.
The Low Pressure warning has a single setting for all sensors; that's a BIG plus if you are changing tyre pressures for different conditions. But the maximum LP warning is, I think, 25psi; a bit low I think for highway especially.
We picked up one puncture through glancing at the monitor when the pressure was still above 25psi.
Maximum pressure is 50psi which is ok for me.
Overall I'm happy with the system.
If running tubeless tyres, then I would look for internally mounted sensors.
