might be time to install a sprinkler system![]()
Hello All,
This thread is about tools used to maintain goods and chattels - I figure protecting your possessions and one's family from fire fits into the scheme of things.
I digress - my wife previously bought a new photo electric smoke detector that was supposedly "insect proof". Within weeks we had insects harbouring inside it and they set the smoke detector off.
Quite recently I bought another "insect proof" photo electric smoke detector and I even sprayed a circle of 6 month long insect surface spray around the immediate circumference of the where the smoke detector was going to be mounted. Once the surface spray had dried I installed the smoke detector. Again, within weeks small insects had found a home inside the smoke detector. Of course they set the smoke detector off.
Our house is an un-screened old Queenslander
Has anyone come across a photo electric smoke detector which lives up to its advertised statement of being "insect proof"? If so can you let me know what brand it is? Plus where you got it from?
Another option - do you think that the photo electric sensor would work if the whole smoke detector was placed inside a length of pantihose or some similar very fine mesh product? Making a cover of commercial insect screen would not keep the little suckers that crawl into the smoke detectors out. This is because they are very mite-like = small.
Kind Regards
Lionel
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
Or insect screens, LOL, Regards Frank.
A cover of "panty hose" is likely too small for the particulates to pass through to trigger the smoke alarm...
A test with "midgee" mesh and some smouldering paper may confirm if that is an option.
It would help to know which unit you are currently suffering with - its not name and shame - just not suited to your application.
So you want a smoke detector with an IP rating, and more so dust/insects than water
So IP6* , but this may be counter intuitive no dust = no smoke ?
https://www.clipsal.com/Home-Owner/P...y/Smoke-Alarms
And we have two types ionisation and photoelectric , one may be more insect resistant. In fact ionisation makes some sort of sense ?
apologies to Socrates
Clancy MY15 110 Defender
