Can you recall the faults as knowing them might help identify what got wet.
 Master
						Subscriber
						Master
						SubscriberHi all,
Looking for some help.
Got stuck in a long puddle today. Bellied out. Car never stopped running. Pulled out backwards. Drove off and parked up 100 metres away to allow water out of car. (I was in the puddle for a while). Engine not stopped. Drove off up hill and engined died. Unable to restart. Quite a lot of faults came up. Have cleared but cannot restart. Thoughts? Ideas?
The fan has bits broken off. Unable to see any water on the dipstick. Signs of slight whiteness in cap!!
Appreciate any advice
Chilly
 Swaggie
						Swaggie
 Master
						Subscriber
						Master
						SubscriberQuite a few....would of saved them but took my card out the other day for some reprogramming.
 Master
						Subscriber
						Master
						SubscriberJust got flat bedded home. Raining here and battery low. Will charge up and see what codes are recorded. Did start once but sounded very sickly and noisy!!
 Master
						Subscriber
						Master
						SubscriberCurrent Fault Codes.
FAULT 1 OF 21
ECU: Instrument Pack
CODE:U0102
Lost communication with transfer case control module
(INTERMITTENT)
FAULT 2 OF 21
CODE:U0132
Lost communication with ride level ctrl module / Lost communication with suspension ctrl module A
(PERMANENT)
FAULT 3 OF 21
CODE:U0138
Lost communication with all terrain control module
(INTERMITTENT)
FAULT 4 OF 21
CODE:U0184
Lost communication with audio unit
(PERMANENT)
FAULT 5 OF 21
CODE:B1A87
Battery disconnection/electronic control unit reset
(INTERMITTENT)
FAULT 6 OF 21
ECU: Engine Management
CODE:P0405
Exhaust gas recirculation sensor A - circuit low
(HISTORIC)
FAULT 7 OF 21
CODE:P1621
Immobilizer code words do not match
(PENDING)
FAULT 8 OF 21
CODE:P0622
Generator field terminal circuit
(INTERMITTENT)
FAULT 9 OF 21
ECU: Transfer Case
CODE:P0562
System voltage low
(INTERMITTENT)
FAULT 10 OF 21
ECU: Automatic Gearbox
CODE:U0155
Lost communication with instrument cluster control module
FAULT 11 OF 21
ECU: Parking Brake
CODE:U0155
(INTERMITTENT)
FAULT 12 OF 21
ECU: Parking Brake
CODE:U0122
Lost communication with vehicle dynamics control module
(INTERMITTENT)
FAULT 13 OF 21
ECU: Parking Brake
CODE:C1A00
Control module
(PERMANENT)
FAULT 14 OF 21
ECU: Ride Level
CODE:U0416
Invalid data received from vehicle dynamics control module
(PENDING)
FAULT 15 OF 21
ECU: Steering Angle Sensor
CODE:U0300
Internal control module software incompatibility
(INTERMITTENT)
FAULT 16 OF 21
ECU: Airbags/SRS
CODE:B1A00
Control module
(PERMANENT)
FAULT 17 OF 21
ECU: Body Control
CODE:U2001
Reduced system function
(PERMANENT)
FAULT 18 OF 21
ECU: HVAC system
CODE:B1B74
Front foot-defrost mode stepper actuator
(INTERMITTENT)
FAULT 19 OF 21
ECU: HVAC system
CODE:B1B75
Front foot-face mode stepper actuator
(INTERMITTENT)
FAULT 20 OF 21
ECU: HVAC system
CODE:B1B76
Front left air blend stepper actuator
(INTERMITTENT)
FAULT 21 OF 21
ECU: HVAC system
CODE:B1B77
Front right air blend stepper actuator
(INTERMITTENT)
How high did the water get in the car? I'm not sure where they are all positioned but maybe an ECU got flooded. Good luck with it.
Oztourer
MY05 TDV6 HSE, Buckingham Blue
Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
 Master
						Subscriber
						Master
						SubscriberThe water was high externally. But only trickled in on the passengers side. Until tow out. Water never more than a very low small puddle on the floor.
Engine area seemed dry!
 Master
						Subscriber
						Master
						SubscriberMan, every time I go out to look it pours down.
Wiring and Ecu around battery appear dry. Lifted fuse box and maybe signs of water there...hard to see and started to pour again.
My obvious thought there is prolly some blown fuses (on the passenger side behind the glovebox), but the below fault will bring up a whole list of what seems unrelated faults as you have listed.
This is a common fault on the D3/early RRS.
"Lost communication with transfer case control module"
When the Transfer Case Control Module gets wet, (pressure cleaning engine bay, water crossings, body seals above failing) eventually it shorts a circuit on the pcb (the computer board), its behind the battery, behind a plastic cover.
When I replace them (round $600 from memory) I open the aluminum housing and waterproof the board with circuit board lacquer, then seal the alum case joints with sealant, finally use rubber grease on the seal for the plastic cover. Spray the whole lot with waterproofing.
The transfer case control module needs to be initialized/calibrated before it will function again. but the vehicle can be driven as a manual, as in use in sports mode and change gears, it will up-shift as you shift, but do be careful as it will also down shift as you shift, meaning it will go down into gears at speeds it prolly shouldnt.
Thats where I would start...
Daz
From Gordons GOE seminar,you need to check/clean the connections at the air-compressor and above the rear strut(cant remember if its on the left or right hand side.
The tranny/transfer ecu was the other location,you are already onto that one adj to the battery.
GOODLUCK.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
