It's most likely the black plastic panel behind the bonnet is either cracked or not fitting correctly anymore.
Another cause of water on the floor is a blocked sunroof drain but this does not usually wet the pollen filter.
Hi guys ,am new to this having only had my disco 4 for 7 days ,but already have a list a mile long to deal with ,nearly have information overload from this forhum ,anyone know how water can be getting into cabin air filter ,enough to saturate it to dripping on the floor ,thanks in advance phill .
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
If you have the alpine roof (factory sunroof) then it could be a blocked drain from that.
Some details in these threads that should help Phill:
http://www.aulro.com/afvb/d3-d4-rrs/...-leak-rrs.html
http://www.aulro.com/afvb/d3-d4-rrs/...otwell-d4.html
A-pillar trim or windscreen molding or blocked a/c are all possible causes. But windscreen molding dripping onto pollen filter sounds like could be your issue.
Link to my D4 Build Thread
D3 2005 V8 Petrol
