Thread: Warning about Wire Rope Replacement with Synthetic
    Mar 2015
    Engadine
    Hi all
    This might be common knowledge but as I was researching winches and synthetic rope upgrades I received this info from Superwinch in the U.S.
    Superwinch recommends not to switch the rope on the X9 over to synthetic as the drum is not rated for the pressures that synthetic places on it (synthetics can either bust the flange of the drum or snap the drum in half if the drum is not rated for such pressure). If you are looking for winches with the ability to have synthetic rope I'd recommend checking into the Talon or the Tiger Shark SR series.
    Regards,
    Tay
    SuperwinchExperts.com
    The Experts in honest winch advice
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    stewie110 Guest
    surprising
    That is very surprising.
    I have been thinking about buying a winch that comes with synthetic rope with the option of going steel if I wanted to in the future. I wonder if there is any problem in reverse.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Never heard that one - it's usually to do with the internal brake. Maybe just steer clear of a Superwinch by the sounds of it. By their own admission, they don't sound so super...
    Mar 2015
    Engadine
    I've done a fair bit of reading into this and there appears to be two issues. As Superwinch states, one is the strength of the drum. The additional pressure on the drum is created by the fact that although synthetic rope does not stretch, it is able to compress and can force its way down through the rope layers when pulling. If the winch is not payed out fully and the rope then rewound after each winch, this pressure builds up with each successive pull and eventually gets too much for he drum. In saying that, I don't know how common this type of failure is with synthetic upgrades. There are several videos out the showing how to correctly lay synthetic rope onto a drum to prevent layers binding up ([ame]http://youtu.be/mLsSqQ44qeI[/ame])
    The second issue is heat buildup from the brake. Good quality synthetic rope winches have the brake on the motor or gearbox but for reputable manufacturers/models that have the brake in the drum, a heat protecting sleeve is placed over the first few meters or so of rope that form the first layers on the drum, preventing heat degradation of the synthetic fibres.
    Apart from the additional cost of the synthetic rope itself (which is coming down all the time), these are probably the reasons why a good quality synthetic rope winch costs a few hundred dollars more than its wire rope equivalent model.
    I'm sure there are many people out that have upgraded from wire rope to synthetic without a problem however they should be aware of these points.
    Happy, safe winching .
    Oztourer
    n plus one Guest
    Warn has similar warnings...
    (not the heating rope crap, that's just an internal brake issue common to all such designs)
