Once you get the hub off it is straight forward.
Knock the old bearing race out with a hammer and punch.
Clean the inside of the hub and the threads for the flange bolts.
I use a large socket and press to drive the new races home.
You could tap them in with a hammer and punch if you had nothing available.
Oil the bearings a little and drive the hub seal home using and old original drive flange. The seal sits 4mm ?? below the face of the hub.
I install both bearings and then offer it up to the stub axle.
Once the hub is on I tighten the inner nut quite firm and rotate the hub to seat the bearings.
Release the inner nut and tighten again until all movement is gone + 45 degress.
install lock tab.
install out nut 65nM
Bend tab in 2 directions
To remove the callipers, there Philips head screw securing the hard pipe, undo these and you can move the callipers without loosing fluid.
Make sure you secure the callipers so they don't fall. You also need to push the pads back a little before unbolting.
				'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
