They're the ones mudder - 80mm OD x 60mm ID and with the double lip. The only seal to use, especially when you have oil lubed bearings.
Sleep well now.
 Master
						Master
						I dont believe it picked up set of wheel bearings and seals sitting here tonight having a cold beer planning my bearing replacement for tomorrow
my wife just said to me why does it say diff pinion seal on the box crap
so they gave me hub bearings with two pinion seals haaa
went through my bush kit found two seals corteco part no rtc 3511g hope these are correct gotta love cairns has anyone used these seals
thanks all
Sleep well now.
Roger
 Master
						Master
						Your good to go. They are the correct seals.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
