Results 1 to 6 of 6
Thread: Rev Limit?
    Mar 2015
    Rev Limit?
    Looking at installing a tacho for my Perentie. I know the 4BD1 has a rev limiter on it, but I can't seem to find what that limit is. Can anyone help me with that?
    put it in neutral, hold the accelerator flat to the floor.
    that's the limit.
    you don't need a tacho in a perentie, you have four usable gears in each range, and theres only about 1/3rd of the usuable rev range overlapped in each gear, its not like you have a 64 speed compound box under there that means you have about 6 gears that will all do the same road speed for various engine speeds to allow you to maintain speed in changing conditions of road and headwind at varying degrees of fuel effeciency as you massage gears to maintain the ideal maximum torque RPM of the engine.
    there are other far more important gauges for you to have especially if you turbo it than the Tacho. The really important ones you either already have or have an idiot light for.
    Feb 2005
    I'm guessing Chris is asking the max. RPM as he is trying to select a tacho.......the way I read his post he doesn't have one fitted.
    I'm not sure what ranges tachos come in.......my bet would be the smallest
    I have never had the need look at a tacho on any type of car I have driven.......on road or of road
    Mar 2015
    well aware that you don't need a tacho.
    I would just like to have one, and trying to work out if I need one that goes past 4k RPM or not.
    Just found a wikipedia page for Isuzu engines. 3200 rpm max.
    Jun 2014
    Waitakere, New Zealand
    Quote Originally Posted by Chris078 View Post
    VDO 0-4000 rpm to match everything else
    Cockpit International 4,000 RPM 2 1/16" (52mm) Tachometer, 12V, 400-1300Hz Alternator Signal | VDO Instruments and Accessories
    Mar 2015
    ended up getting both a clock and Tacho (no 2 in the picture). got the black bezel on the clock so they will all match.
    for less than the cost of a VDO tacho.
    now just have to take the truck up to the auto electrician to get the
    'W' connector installed on the alternator.
