Results 1 to 10 of 11
Thread: Cracked Cylinder Head
    Feb 2014
    So, not much info on here about a cracked cylinder head for the 2.25 it turns out!
    I thought this one would be an easy one to research
    So after buying an entire car for the engine, i now have a cracked head, not fun! Its between #2 and #3 and is a nice neat straight line that had no real effect on the head gasket what so ever. The previous owner didnt mention any symptoms for the failure and Im not surprised, I doubt it would have even affected performance.
    Now I have the new woe of finding a solution, I am trying to steer away from the $900 reco replacement head because...well thats just silly.
    Apparently cast iron repairs are becoming more common these days, being such a simple and accessible fault, I would take a guess at saying its possible?
    Find another used head? Has anyone got one laying about??? as long as its not cracked....ill buy it! haha I fear if I go down the line of getting another engine for the head ill end up buying another whole car like i did last time
    The remainder of the engine is in superb condition, 010" undersized bearing and 040 oversized bores. I was seconds away from thinking that I had a perfect engine, bugger.
    Has anyone been in my boots with these engines and what have you guys done?
    JDNSW's Avatar
    Cracked heads on these engines are quite unusual - most likely associated with skimming an early type 7:1 head, but possibly either a manufacturing fault, or it has been badly overheated at some stage. (I have never seen one cracked, or heard of anyone else who has first hand experience of it before now.)
    There should be someone on here who will be able to supply another head - try "wanted" in Markets.
    Feb 2014
    Thanks John,
    Im going thru some quotes for cast repairs now, at $130/hr either solution wont be cheap
    JDNSW's Avatar
    I would not bother even trying to repair it - there must be a lot of engines around gathering dust, and even if the engine is worn, the head is almost certainly uncracked - at worst you would be looking at new valve guides and possibly seats, assuming your head has good valves and gear.
    Jul 2012
    midwest W.A
    Chemiweld
    WA
    That is a weird crack. Almost as if those middle 2 bolts were overtorqued and the others left loose so the head could flex in the middle.
    I have seen a couple of cracked 2.25 heads (one 7:1 and one 8:1 S3 head). If memory serves they were both cracked between the valves though. The latter 8:1 head I bought and then later found out it had been repaired some time ago. The engine machinist I was using at the time was happy with the repair and had no problems with using it.
    Feb 2014
    Thanks for your input guys, I have got 2 quotes for a repair job, both being $250 plus!!
    looks like i will be sourcing another head at that cost!
    loose bolts on one side of the engine, Seen that before but usually only after the donks been then overheated and abused while hot or hydrauliced.
    It can be gouged, welded and ground back, but its a little costly to do as youve found. If it passes a pressure test you can chemically bond it and you wont have a problem with it, the trick is getting somewhere to do that. If it can be made to leak coolant through the crack then you have more options. But if its leaking coolant through the crack I'd suggest you're better off replacing the head.
    Check the deck and the piston heights just in case its been cooked and warped the block or its been hydrauliced.
    darwin, nt
    Cracked heads aren't common in these motors but they do happen. The first Landy I could have had turned out to be beyond my means because of a small crack like that one radiating off a cooling gallery. I also understand that they can sometimes crack across the valve seats too.
    I wish I had a photo I could share of the worst crack I've ever seen in one of these motors, I still have this motor in my wrecking yard though. Both the block and the head are cracked between cylinders 1 and 2. The cracks are probably more then half an inch deep in both and as wide as a fingernail is thick! Obviously scrap but I've kept it for spares (eg. valves, studs, etc).
    Oct 2014
    Northern NSW.Australia
    I found 6 new boxed bare heads at Murwillumbah, Southside wreckers.
    I was looking for a series 3 type, at the time.
    Themadmob got one for his series 2, as the were an earlier type, with the deep thermostat
    housing.
    Bare, boxed, but some had the wax paper folder back.
    He Paid $100.
    Just need some forum members, heading south, to get it to you.
    Whitehillbilly
