Results 1 to 10 of 23
Thread: seat height
    May 2009
    Perth Western Australia
    seat height
    Drivers seat height adjustment. Has anyone else noticed that the height adjustment self lowers occasionally? What is the mechanism? I know I have put on a few kg but its not that bad....
    Dec 2011
    Forrestfield WA
    You (or someone else) are probably pushing down the height adjustment lever beside the seat when getting in and out of the car. You push it down to lower and pull it up to raise the seat.
    Bob
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by Aaron40 View Post
    Actually I have noticed this. I always seem to be putting it up and I don't think my wife is changing it (only two drivers). I'd swear it must move down but it's imperceptable. The mechanism could be getting bumped but I don't think so.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Oct 2013
    Old Toongabbie, Sydney NSW
    A bit out there, but do you have the seat memory option? If so, you may be pressing the buttons accidentally and be getting an alternative lower setting by accident. It happens to me occasionally as I hit the memory button with my elbow.
    Martin
    The manual seat height adjustment does not maintain height, slowly drops over a few days. I had it looked at, had parts replaced etc. In the end I gave up and got use to sitting in it at its lowest height setting.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by Ferret View Post
    That sounds like my experience, although I haven't had it looked at.
    Dec 2009
    SW WA
    I've read that placing a stiff foam or other block under the lever so it can't be pushed down fixes the problem. The more you need the seat higher the more chance you'll bump the lever getting in and out.
    Williams West Aust
    Interesting,I dont think Ive ever messed with the height adjustment,Aaron rang me about it.
    I sat in the thing in the showroom when it was delivered and was very comfy so left settings as they are.Being rather large I probably dont need elevating
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Dec 2011
    Forrestfield WA
    Mine doesn't go down, ever. But if I sat on the lever when getting in and out I think it would, as I said above. I always have it at the highest setting.
    Bob
    Brisbane,some of the time.
    Mine sinks as well,now i just leave it where it lowers to.
    It is an LR.....
