Results 1 to 10 of 12
Thread: No 5 parts diagram and part no list
    Sep 2010
    Moe, Victoria
    Is there such a thing as a parts diagram and part no list for a No5?
    In particular I'm looking for the parts no's for the inner seal, lock nuts (can you get regular hex lock nuts?), lock washers (ninja star looking things, or equiv for hex lock nuts), gasket for cup.
    Can you buy replacement lenses for the tail lights? Unfortunately one of the Glass Lucas lenses is smashed.
    Western Victoria
    Have you asked on REMLR?
    They may have that info in their archives.
    Canbeera
    ...we're working toward a number 5 restoration, with info
    101-148 - REMLR Wiki
    Sep 2010
    Moe, Victoria
    Quote Originally Posted by Mick_Marsh View Post
    Not having much luck with REMLR - tried to create an account and never received email confirmation. Sent in a form and have had no reply.
    Have had a poke around, and read Carzee's restoration page ... which suggests the lights are going to be hard to replace and doesn't yet contain info on the seal or lock nuts/washers ... so still got fingers crossed for some advice here.
    Sep 2010
    Moe, Victoria
    Thanks to the wiki and REMLR I found the parts scale for the no 5 and relevant excepts re the axle are below. Searching via these part numbers hasn't returned obvious suppliers...
    Sep 2010
    Moe, Victoria
    OK, I think I've found the lock nut and washers....if anyone can confirm that would be great.
    KM(L) and HM .. T lock nuts - KM 9
    MB(L) lock washers - MB 9
    LandroverScott Guest
    Quote Originally Posted by towe0609 View Post
    Howdy,
    REMLR forum should be automatic replies to the email address you submitted, REMLR inc registration - I updated them yesterday
    Sep 2010
    Moe, Victoria
    Still looking for a part number and/or supplier of the Gasket (Part 12) I thought maybe it would be the same as a drive flange gasket for a series land rover (231505), so I bought some, but they are a few mm too small.
    Any help appreciated.
    Sep 2010
    Moe, Victoria
    These gaskets can be obtained from
    rubber products, rubber distributor, rubber manufacturer, Melbourne, Sydney, Brisbane, Adelaide, Perth, Australia
    51 Sparks Avenue, Fairfield, Victoria 3078
    Ph: 03 9482 7222
    Shown in their gasket listing as
    GASKET AXLE GREASE ADE(V)50-36
    around $17 per unit + delivery
    I think I'll buy myself a decent punch set and a sheet of gasket from supercheap or the like.
    Sep 2010
    Moe, Victoria
    Just for the sake of documentation in case it benefits someone else, the seal (Part 003 in the diagram) is a RTC3510 or Corteco 19029100B
    I wouldn't recommend opening this link unless you really have to as it take ages to load being a 350+ page document. But it does show the exact dimensions of the seal.
    "www.corteco.com/fileadmin/user_upload/media/service/2015_Oil_seals_by_design_web_catalogue.pdf"
    Article Number: 19029100B
    EAN: 3358960368904
    Inner Diameter 1: 58.72 mm
    Outer Diameter 1: 85.09 mm
    Height 1: 7.94 mm
    NBR (nitrile butadiene rubber)
