Results 1 to 10 of 20
Thread: Advice on hand held walkie talkies
    here
    I'll have the UHF with the big ariel in the car when travelling but when we walk about wherever we're staying I'd like the family to carry a walkie talkie.
    So the criteria - Must be really simply to use - turn it on, set the channel, push the button and talk. Must be robust - able to be dropped at times on rocks. Must be powerful enough for when we're apart or one of us goes for a walk.
    What do you recommend?
    in the wild New England, NSW
    I think it is worth having 5w radios
    GME example:
    GME TX6150 CommKit 5W 80CH UHF CB Handheld Twinpack
    https://www.gme.net.au/catalogue/han.../tx6150tp.aspx
    But if you think 2w would be enough (personally I think you'd be disappointed)...
    GME example:
    GME TX675 Twinpack 80 CHannel UHF CB Handhelds
    If you need a cheaper option Oricom (often sold through Repco on special) is a brand that works OK
    Mostly any established brand will have similar performance, most incl some GMEs are sourced from China
    Watch out for the claimed distance achievable - this assumes ideal conditions which rarely exist in practice.
    For example 5w handheld in steep country = 4km line of sight or less
    Mar 2014
    Blackburn, VIC
    I bought a couple of these:
    :: Uniden Australia ::
    Alloy body, very tough- although my workers managed to smash off the belt clip on the first day... Apart from that, it's a great unit. Comes with a proper car cradle with 12v adapter so you can use it in the car if you wish. Speaker mic is good and loud, no distortion. Good rubber aerial that can be unscrewed to fit a larger fixed aerial for in -car use, though an adapter is required. 2 LiPO batteries, everything you need. I got a pair in the tradies pack, comes with a nice weatherproof case for under $500 on fleabay.
    May 2014
    Tamworth NSW
    I've had a uniden like that for the past 5 years and has been great. Sturdy and good quality too
    -Mitch
    'El Burro' 2012 Defender 90.
    Western Victoria
    Whatever you get, try it out first.
    I have a great old Uniden. (UH077 I think.) I decided to get one of those kits of two. Uniden, of course. I bought a cheap kit, made in China. Under $100. I was very disappointed with the quality or lack thereof.
    Whatever you get, see if you can try it out first. In store should give you enough of an idea.
    Brisbane,some of the time.
    Quote Originally Posted by 87County View Post
    GME example:
    GME example:
    We have the GME TX675 twin pack.We use them at work and when away as well,found them to be great.
    Their range is so much better than the old 2w GME we had for ages.
    here
    Cheers all. Ended up buying the tx6150 kit with the water proof box. I'll get round to using them soon. Better do a little reading on what channels to use but more importantly what ones not to use
    That's what we got too - we've found them quite good except the scan isn't fast (not much need to use it for the purpose we got them though).
    The sep mic/speaker is good as well if you've got the radio in/on a backpack or belt.
    We've found that the battery time is at least as good as what is claimed.
    Very good piece of kit for when a group splits and takes different paths.
    cafe latte Guest
    I know the OP has already bought his radios, but I thought I would add my 2c
    In the fire brigade both town and rural and on the farm I have used most radios, simco and Icom are the best IMO and my fav is Icom (ic-41s) I use these in Brigade and also I have two of my own on the farm they are small and really tough. Mine have been wet covered in cow poo and dropped on rock more times than I remember, my misus dont ask how many times They are super clear too.
    Best budget radios are IMO Quansheng, they are a programmable dual band (vhf uhf) radio. Clarity is not at the level of an icom, but it is still very good. When you bear in mind that you could buy a stack of these for the price of a single icom radio it is very good indeed. I have a couple of these as spares for the farm and they have had a bashing too, not as tough as an icom, but for the money they are stunning.
    Simco are a bit big, GME are not as clear as the icom and I dont think as tough either, icom my clear fav
    Chris
    Feb 2010
    Townsville, QLD
    I agree with cafe latte. I have used Icom and Tait 5w hand held radios for over 11yrs in the mining industry. They get buried in slurry, chemicals, dropped from height, soaked in rain. I've never had one replaced in that time due to failure. The Icom ones recover from a soaking quicker (the speaker goes quiet when they get wet), but both are definitely a true IP68 and can handle anything you will throw at them in a lifetime.
    Battery life on the Icom is normally 36hrs with constant (ab)use and someone talking on it nearly all of the time. On standby (switched on but no activity) we often get 5 days out of a battery before recharge. Both have a clear 14km range with my use which is better than the ones in our vehicles.
    Keithy
