howdy all thanks to all the help here I got everything done plus more,
rear hub bearings, and seals not so bad, replaced the rear brake discs and pads, as well, also did the transfer case output flange.
also did the leaking rear diff pinion on the salsbury have one small problem seems I have a rubbing brake pad rear right side thinking stuck brake piston
but not sure does seem to be rubbing on the disc anyone got any ideas
thanks for all the patience its been a crap two years with health and all
this has helped me get my confidence back
cheers all
