Results 1 to 10 of 18
Thread: question for people with sway bar disconnects
    Jan 2011
    Burpengary, QLD
    What do you do with the sway bar once it's disconnected, just let it rest on the bar below (not sure what it's called or is there a preferred method of holding it up?
    Thanks as always for any suggestions
    Feb 2012
    Carnegie
    I've seen them tied up with bungee cord.
    Feb 2010
    Townsville, QLD
    Could just disconnect one and leave the other attached... It'll still go up and down but won't limit sway.
    Jan 2011
    Burpengary, QLD
    I was wondering about just doing one side, does it still allow decent flex in the front, as long as the free end can't hit anything that would be great .
    May 2010
    Mindarie, Western Australia
    I've got the sway bar disconnects on mine after i bent and snapped one of the originals. So far I've not undone them to gain the extra flex. Too lazy I think
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    Jan 2011
    Burpengary, QLD
    I just thought after going to the trouble of fitting the lift kit I should try it before the enthusiasm ran out, like you I suspect that I'm too lazy to disconnect often.
    Feb 2010
    Townsville, QLD
    I have a set that I will be fitting to my Silver P38 when I install the lift kit. It will be a regime to disconnect the swaybar at the same time I lower my tyre pressures for low range driving. It's like putting underwear on really :-p
    Keithy
    Jan 2011
    Burpengary, QLD
    I am off to the glasshouse mountains tomorrow so I will try to remember my underwear!
    I will be giving the disconnecting a go as well, might take a bungee or leave it hanging, so much to decide !
    Mar 2009
    Port Stephens N.S.W
    On my D2 I just cable tie the disconnect link back up to the sway bar. It disconnects at the bottom. Carry a handful of cable ties and a set of side cutters in the passengers door pocket.
    I only have a disconnect on one side. It greatly increases the amount of down travel on the front axle. The D2 lifts a front wheel pretty easily when it's still connected.
    Just make sure you reconnect when back on the black top.
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Jan 2011
    Burpengary, QLD
    Well I went with just disconnecting one side just to get an idea of the difference it might make, didn't seem to make it a death trap in the 5 minute drive on tarmac back to my mates place after the drive and seemed to help with front end flex, as hopefully the pictures show
