Results 1 to 10 of 11
Thread: Cummins fuel problems - What ya got?
    Dec 2013
    Kickin about QLD
    Hi guys. Got a bit of an issue with our top lifter (like a container fork lift) at work.
    Its been running rough for about 2 weeks now and its getting worse to the point its stalling. Its as if its not getting fuel and not firing on all cylinders.
    We've had a real good go at trying to fix the problem, but I'm now coming to the wisdom of AULRO members.
    The actions we have taken are, run injector cleaner in the fuel, bleed from the injectors (about 10 times), replaced all the rubber fuel lines, replaced both filters, replaced all brass washers on fuel lines, blew compressed air through all lines to check for fuel bug, pressurised the fuel tank with compressed air hopping to find a hairline crack, taken apart lift pump (still makes vacuum) also kicked and swore..... a lot.
    The only thing I can think of now is a problem in the tank it self, maybe a crack in the pick up.
    We are more than happy to hear any suggestions at all. what have you got for me???
    put a t piece in the delivery line from between the lift pump and the injector pump. fit a tap or blank to it.
    get the engine running and then open the fitting, if its pumping frothy fuel then you have a fuel supply issue
    if it starts to die as soon as you open the fitting then you have a delivery problem from the tank to the lift pump or the lift pump itself is faulty.
    get a jerry of fresh diesel some fuel line and a facet pump and bypass everything but the injector pump give it a run.
    If that doesnt get you running smoothly you have a problem in the injector pump, from there it comes down to which pump are you running?
    Dec 2013
    Kickin about QLD
    Righto. Ill have a crack tomorrow morning. Thanks mate
    Adelaide
    Blocked finger filter on the fuel pickup in the fuel tank?
    I have seen that in a bus once.
    Peter
    D4 TDV6 2014, Tow Pro, Traxide, GME, Clearview.
    D3 SE 2008 2.7, Traxide, Prodigy P2, Light Force, GME, Sold to my son!
    D2 TD5, sold but missed.
    Dec 2013
    Kickin about QLD
    Quote Originally Posted by whitedisco View Post
    Peter
    I've blown air back through the lines to the tank. But still runs rough on start.
    Moruya Heads/Sth. Coast, NSW
    If it is the type Cummins engine that pumps the fuel through the head to the cam/rocker arm operated injector, then it could be a number of things including blown or worn O rings in head or the rocker needs adjustment, may need to get it pressure tested, Regards Frank.
    Gosnells WA
    What's the engine model / serial number?
    Should be on the timing cover on the right hand side (looking from the front) or on the rocker cover
    Ben.
    Team W4 - WEBSITE
    Aug 2010
    Sunbury, VIC
    Large container fork would run a 6B or 6C - both mechanical engines, but if it's fairly new, it could be running the electronic versions - ISBe or ISC.
    Jul 2012
    midwest W.A
    Quote Originally Posted by J RAD View Post
    Only running rough on start?
    Sucking air into system somewhere.
    Gosnells WA
    Quote Originally Posted by bacicat View Post
    That's what I was thinking. Do the 6Bs and Cs have the small fuel strainer in the back of the fuel pump like the QSX15s do? From memory you have to remove the fuel inlet fitting and dig the strainer out from behind it with a scribe.
    Ben.
    Team W4 - WEBSITE
