Thread: rear 12 volt socket
    pjgrandad Guest
    rear 12 volt socket
    Hi all,
    Just wondering what the rated fuse / amp draw is for the rear 12 volt acc socket left hand rear panel on a MY13 Discovery 4
    Quote Originally Posted by pjgrandad View Post
    Hi all,
    It would be listed by LR as 10amp max, but that would be way more than it could handle for any length of time.
    Dec 2011
    Also the wires are pretty thin so a significant voltage drop as you increase the amp draw.
    Baz
    May 2015
    Has anyone tried running a 12 volt fridge off that socket?
    Apr 2011
    Coffs Harbour
    Yes, I run a 50l Waeco off that socket ( no dual battery), but I pull the temp down on 240v overnight and then fill it before putting it in the car. I do not pull it down in the car as I do not believe it has the capacity due wiring.
    2012 Fuji White 3.0 D4, Rear view camera, Hi-line sound, E-diff, Xenon lights, ARB winch bar, Lightforce 240 50w HID. Brads sliders.
    Williams West Aust
    I have run my 80lt Engel from there,didnt blow fuses,didnt cool as good as it should either.
    Now have a Traxide dual battery system,the factory plug is now wired into the DBS making the plug live all the time rather than whilst the ignition is on.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2013
    Darwin
    If the rear one only delivers 10A, is that the same for the ones up the front, and in the second row?
    Not yet fitted with dual battery, and doing a HUGE trip ( Sydney to NT) in the next week. Planning to run on 240v extension lead by night, but will the fridge (60L AR run efficiently enough off the rear, or will it run better off one of the fronts due to shorter cable run and less current loss.
