Thread: 300tdi waterpump&alternator check?
    Dec 2010
    cairns
    howdy all thanks for the help im nearly at the end of my maintenance list, but I have a noise coming from either the water pump or alternator,
    just checked the water pump, and alternator, also the tensioner bearing
    waterpump has a bit of play, and if I move it in and out get a slight clunk.
    no overheating its about 50,000 old, also the alternator has some minor play its a chinese one about 60,000 old still charging good,other bearings seem good but will replace them anyway any help appreciated
    schuy1 Guest
    If you have any noticeable movement in those items, replace ASAP. Otherwise you can end up with the belt jumping a groove and shredding it self. Makes a helluva mess in the engine bay I can tell you!:O Mine tore all the soundproofing off the underside of the bonnet, which then wrapped itself around every thing that even thought about rotating! Made for an entertaining hour on the side of the road in summer :/ and all from a water pump with 3mm runout.
    Cheers Scott
    Aug 2012
    Logan,Queensland
    New water pump for you I think.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Dec 2010
    cairns
    water pump brand
    Quote Originally Posted by jboot51 View Post
    chees mate whats the best brand local blokes stock airtex brand?
    Aug 2012
    Logan,Queensland
    Airtex is reliable. I've had no problems with them.
    HS2.8 TGV Powered
