I would`nt personaly seen enough broken aerials broken in this manner
Have you thought of a mount off the spare wheel carrier or i have seen some mount aerials above tail lights off the body panels (carefull flimsy) or off the rear chassis .
In saying this it all depends how you use your radio and what for as most aerials need a ground plain to work properly for any sort of distance .You can can get aerials which are not ground plain dependant
So i think a bit of research is needed on your behalf
