Results 1 to 10 of 16
Thread: Pumping up tyres
    May 2003
    On The Road
    MoveLater2 Pumping up tyres
    I have a
    http://www.aulro.com/afvb/trailers-v...van-tyres.html
    (probably chinese but bloody heavy)
    compressor that I'm using to inflate my van and car tyres.
    At the moment it has a screw on the valve type fitting and a gauge that reads in bar.
    I'd like to fit something like this
    but I am concerned about when the trigger is released, there will be pressure build-up in the line as there is no tank or (I think) no pressure cut off.
    The ideal way would be just to let the compressor run,, but do I then have to fit a reservoir?
    The air line itself will act as a reservoir. You will need to fit a pressure switch and relay to control the compressor.
    Aaron
    mikehzz Guest
    That's why the arb compressors are so good, they switch off. I saw a new bushranger one that does too but pricey. I've blown the hose too many times on my cheapy so I just switch the unit off between wheels. I like my digital gauge.
    May 2003
    On The Road
    May 2003
    On The Road
    anyone know a (national) company that sells shop air line by the metre?
    This is a safety pressure relief valve. It will prevent damage to the system, but won't turn the compressor off. You want a pressure switch.
    Aaron
    Oct 2011
    Fremantle WA
    Yep, aforementioned Pirtek in a related thread. Found the local people (O'Connor) very helpful with old style service.
    May 2003
    On The Road
    Taking notes Gavin?
    your beast will be difficult enough just refueling!
    May 2003
    On The Road
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    Thanks Aaron, I'd like to just let the compressor run, hopefully not to long between tyres, switch off between sides, start again.
    Ellendale Tasmania.
    BTW, that little black button on the side is an air release, if that gauge is acurate, you can use it to let air out of your tyre if you pump it up to high.
    I have a Big Red by Thomas, it doesn't have a pressure cut off, never had an issue in 10yrs, also have that exact same compressor, only used it twice, wouldn't blow up a party balloon, bloody hopeless, I bought it for Ness, having twin cylinders I thought it would be good, but I thought wrong, oh yeah I forgot to add, I have two of those things in your pic, one with a normal size hose and the other has about 5mtrs of ARB compressor hose, they work much better than that silly screw on thingys.
    I have some spare ARB hose if you want it.
    Cheers Baz.
    2007 BMW R1200GS
