the hemp rope is probably shot but the synthetic slings and SWR stuff should still be in good order.
the "book life" for lifting gear from memory is 10 years most slings that require certification have a stamped expiry date on the load limit/SWL tag.
if in any doubt just turf it or restrict it to use where if something goes wrong the result wont have any consequences you're worried about.
for the size stuff that is typically used in the private 4x4 world its almost always cheaper to turf and replace at "end of shelf life" than it is to have it re certified.
