Results 1 to 10 of 13
Thread: 300 tdi Clutch problems AGAIN!
    Nov 2013
    Jarrahdale W.A.
    Hi Landie Lads and Ladies - needing your combined wisdom, knowledge (and encouragement).
    I thought I was having a really bad backlash problems. First thing in the morning when I would start the Defender, I would releases the clutch it would go BANG and shudder, then it would be fine. That was till earlier this week when I started dressing the clutch a few times before I put it into gear - it then engaged smoothy and no more problems the rest of the day.
    That was until the clutch started slipping on the way up Jarrahdale hill! Oh no!
    The clutch was replaced only 18 months ago due to a complete failure - the centre ripped itself apart and stranded me in Brookton. So, I really don't feel that I shouldn't need a new one at this stage.
    It was suggested to me that I needed to adjust the clutch freeplay, but I don't know how to do that.
    Do I need to get another clutch?
    Is is worthwhile getting a heavy duty one?
    Anything else you guys can think of he tell me?
    Thanks for taking time to read these sad ramblings. Looking forward to your replies.
    Keith
    '94 300 tdi
    Geelong, VIC
    Do you have a bit of free travel at the top of the stroke when you first start to push on the pedal? There should be some but I don't recall the measurement. It can be adjusted via the master cylinder pushrod. You get to that by removing the the rectangular cover on top of the clutch pedal box in the engine bay.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    if its engaging suddenly then its usually the throw out bearing carrier sticking on the input shaft tube on the front of the box, the slave sticking or the MC not releasing due to mis adjustment.
    to check take the cover plate off of the clutch tower and make sure theres some free play on the push rod into the MC.
    Nov 2013
    Jarrahdale W.A.
    Ok, thanks guys, you have shown me the first job, I will check the free play via the master cylinder.
    I know I would get help here. Thanks.
    Keith
    Nov 2013
    Jarrahdale W.A.
    Ok, another question.
    Does the slipping clutch indicate that it is about to fail (don't want to go through that again), or might it be the lack of adjustment.
    With the check and adjustment of the free play alibi ate the problem?
    Btw, this clutch was put in by an experienced LR mechanic shop.
    Feb 2005
    If it doesn't have free play and you adjust it may not fix the problem or it may......there could be a combination of issues
    You can check the free play from the driver seat.....you should be able to depress the clutch maybe 5mm without effort than more effort should be felt.
    Have you dropped into the workshop where the new clutch was fitted??
    Nov 2013
    Jarrahdale W.A.
    Haven't been to the workshop yet - they are an hour and a half away from me. Will check the adjustments before I do anything else. Thanks.
    if you have free play and its slipping you generally need to pull the engine or the box.
    Nov 2013
    Jarrahdale W.A.
    Ok, so I followed the advise given, I sorted out the freeplay on the clutch peddle.
    After reading my manual I found there was none ( you would think I would have worked that out on my own!). Anyway I adjusted it and what a difference that made. The gear changes are smoother and the clutch peddle is lighter! Who would have guessed.
    Hopefully the clutch is still ok - driving up the same section of Jarrahdale Hill tonight there was no slipping!
    Thank you all for your help. What a great forum!
    Geelong, VIC
    Good work
    Steve
