Thread: Canuck in trouble
    Jul 2012
    Canuck in trouble
    Hello from Brisbane.
    In a much earlier life I spent a few enjoyable years at a university in British Columbia - more recently been following the local Land Rover scene as an outside member of Roverlanders BC with an aim of some day getting back over there to run around the backblocks again.
    Anyway, one of the members is undertaking a drive from London to Singapore in a 1956 86" with his family and has been having a bit of trouble one way or another with the truck. They are in Turkey getting ready to cross to Iran.
    The most recent problem relates to a noise from the front drive train which I thought some of the AULRO Series brains trust might venture an opinion on.
    Best to let you follow the ongoing script from the Roverlanders BC site:
    Initial query from Question poser:
    ?Ok so this has been odd.
    In our Series 1 (86") as we were driving east through Turkey we experienced a loud squealing noise coming from the front of the drivetrain. Sounded like a bearing starting to go.
    It only happened with the front hubs unlocked. When I locked the front hubs the sound went away. So I guessed a front wheel bearing. The noise was louder on the right side so we pulled the front hub and the inside bearing was pitted (it was pitted before we left but what the heck I changed it).
    The noise is still there when the hubs are unlocked. When the hubs are locked it goes away.
    When I put it in 4WD with the hubs unlocked, the noise also goes away.
    So the noise only happens when the front drivetrain is turning at the same speed as the rest of the drivetrain.
    So, if it's not a wheel bearing, could it be front output shaft bearing?
    I enter Iran tomorrow so I don't have a lot of Land Rover shops around to help me troubleshoot.
    Any thoughts??
    Response 1:
    ?From your description, it can only be the hubs. When it is happening, nothing in the front drivetrain is moving other than the part of the hub attached to the wheel hub. Just leave them locked. There is nothing to be gained by having unlocked hubs?.
    Question poser reply:
    ?Yes that was what I thought but then I started to get this juddering when slowing down. Plus I get a faint "cooked bearing" smell when I exit the vehicle?.
    Response 2:
    ?It has to be a hub. If it were me, I would just leave them locked and not worry about it. Actually, if it were me, I would remove them and put on stock drive flanges. If you want to investigate, take the hubs apart. They are probably full of mud instead of grease?.
    ?I've had them apart. They look fine. Greasy and perfect. Any thoughts what could make the sound when I depress the clutch pedal when slowing down??
    Response 3:
    ?When freewheeling hubs are fitted and are not engaged then you don't have the benefits of splash lubrication in the front hubs - not what the design engineers had intended. If an owner is determined to run with freewheeling hubs and is commuting regularly then it would be advisable to engage them every so often (weekly?) to ensure there is some fresh lubrication splashed around. If the vehicle is rarely used then you are not doing the workings any favours by running with the hubs disengaged. Other drive line issues would need to be dealt with separately. I'd start by looking at your u-joints, prop shafts and/or half shafts?.
    The discussion is ongoing but if someone can help I will pass it on. Or log on to the Roverlanders BC site and look in the technical questions for the post by Ray Hyland on this issue.
    Neil
    australia
    Quote Originally Posted by S3ute View Post
    Any thoughts??
    Response 1:
    Response 2:
    Response 3:
    Neil
    hi neil take the front propshaft and see how it goes regards jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    in all of that there is no mention of checking the lubrication in the various front axle sectioins, but i agree with russellrovers, take the front prop shaft out and also unlock the free wheeling hubs,
    then the front axle is not running and the only rolling things are the front hub/wheel bearings
    Safe Travels
    harry
    Another Bush failure
    In the front output shaft housing of the transferbox there is a bush that locates the shafts where the four wheel drive engagement coupling operates, this can be a failure point when freewheeling hubs are fitted.
    While in two wheel drive mode with the original drive flanges fitted, this bush runs at near the same speed as the front prop shaft and then does a lot of work when free wheeling hubs are fitted, so it pays to inspect this bush for excessive wear or being too tight when free wheeling hubs are first fitted.
    Cessnock NSW
    Could it be transmission 'wind up' I have had that happen in my Series 1 about 40 odd years ago, it made a funny squelling noise as well, I hope they fix it cheers Dennis
