Results 1 to 10 of 21
Thread: Towing on sand with a TD5
    Brisvegas, QLD
    Hi all,
    We are planning on taking our camper trailer to Bribie and/or Straddie over the school holidays. It's a Conqueror 390, which I guess would weigh around 1300kg when loaded. Just wondering:
    - will our TD5 wagon have any issues towing it on sand? I've had it behind the defender on the road without any issues, but I'm a bit worried it may struggle to drag it through soft sand.
    - what do I do with tyre pressures? When I'm not towing, I've generally let the tyres down to low 20's PSI. Will I need to go lower with a trailer behind? And what pressure should the trailer tyres be at? I realise it will depend alot on the condition of the beach, so I'm just after some rough guide lines.
    Sean
    Apr 2012
    Endeavour Hills, Victoria
    I don't have a lot of experience and others on here may correct me but, I've always been told to match your trailer tyres' pressures with the towing vehicle when on sand as a general rule of thumb. You may need to go lower but it depends on the conditions of the sand. I don't think you'd have any issues with the Td5 considering that I've seen other vehicles with less of a vehicle tow on sand.
    Nathan.
    May 2008
    cairns
    If it's a post my02 get a stage 1 remap with a little more boost as well and won't have to worry about the trailer . in fact you will forget you have one attached
    Oct 2007
    Brisbane West
    Tyres nice and low...just keep airing down in the soft sand as needed with obvious caveat about low speed and no sharp turns. Use low range in the soft to give plenty of grunt. Obviously try to keep momentum up. Of course air back up for higher speeds for eg on hard sand or black stuff. Long handled shovel. Centre diff locked if you have it.
    May 2003
    On The Road
    Fairly high pressure situation,, barge, school hols, sand, beach,
    can you practice somewhere with the trailer beforehand?
    most LR rims will support tyres air'd down to single figures,
    if you have to,
    if you take it easy,,
    naw, better advice is just be on full boost everywhere,
    Brisvegas, QLD
    Thanks for the replies guys.
    Another mate has suggested a chip/remap as well, so I may look at that if we struggle at all on this trip.
    Anyway, I'm reasonably confident the car will handle it OK, I was just hoping someone would say "yeah mate, we tow our trailer on the beach behind our TD5 deefer all the time, no worries!".
    And if the worst happens Pedro, full boost it is!
    Sean
    Dec 2008
    Tewantin, Qld
    I've got an MY12 Deefer but used to have 99D2-TD5 manual.
    Did Fraser at least a dozen times towing a trailer about 1200kg . Hook point up to the cape, over the back of Ngkala rocks and from orchard beach to west coast.
    I found thru trial and error that keeping the trailer pressure about the same as the car was a good choice. The lower the better on soft sand (of course) but when you drive on the beach, the up side on the washouts will still pinch the tyres on the rims if you hit them too hard. I discovered this once cause i'd pumped up the car but didn't worry about the trailer.
    The D2 did fine without a chip as long as traction control was disengaged. If it was on the D2-TD5 would struggle in the soft sand, all the power would be sapped away by the traction control. If you have traction control in the 2000 Deefer i'd say it's probably the same system, so if you have it turn it off if you can.
    Oddly enough the traction control in my MY12 Deefer gives me much better performance on the sand, so they must have done some tweeking.
    You'll be fine just keep the revs up above 2K.
    Have a fun.
    Brisvegas, QLD
    So we're back from our trip, and had mixed results towing the trailer. We aired down to 18 before hitting the beach, and managed the entrance track to the beach in high with no problems. Then as soon as we hit the soft sand on the beach we stopped. After changing to low range we managed to get going again.
    The tide gave just enough room for one car to get on the harder sand. We stayed in low initially, wich was pretty slow going. My mate in his 200 series went past us, and we fell a fair way behind, so I changed in to high to try to keep up. This was fine until we had to go up into the soft sand when we passed a car coming the other way. Again we got stopped and this time low range couldn't save us. So out with the shovel we started digging. My mate came back and another guy also stopped to help. They both had max trax, so we were out pretty quickly.
    Similar things happened a couple more times- I can't remember exactly what happened, but basically we were forced to stop each time on the soft sand and couldn't get going again. Eventually we lowered pressure to 14, and my mate snatched me to get out of our last bog on the entrance to our camp site.
    No more problems after that. Our trip off the beach at the end of the week also involved a bit of driving on the soft sand, but this time I stayed in low the whole time, and any time it looked like I'd have to hit the soft sand I made sure I changed down before hand and the revs were high.
    Low range + low tyre pressure + high revs = no hassles. Basically all the advice given previously in this thread that I didn't pay quite enough attention to ...
    Oct 2007
    Brisbane West
    Mate did you have the trailer pressures down also?
    Brisvegas, QLD
    Yep, trailer pressures were the same as the car.
