Results 1 to 10 of 20
Thread: Puma diffs
    Feb 2013
    Queensland
    Puma diffs
    Can any one tell me if Salbury diffs will fit a 2001 defa and where I can get a set and how much thanks all for your help.
    99.87 MB
    Quote Originally Posted by laney View Post
    This has been done. but I'm not sure re cost. You will also need a Salisbury tailshaft.
    Slunnie
    Safety Bay
    Keep your original housing with Ashcroft centers/axles. Pat
    chook73 Guest
    Quote Originally Posted by PAT303 View Post
    I second this, much better clearance and just as strong......
    Oct 2011
    Burra NSW
    2001? It should already have a Salisbury in it..?
    NSW far north coast
    Quote Originally Posted by chook73 View Post
    Not better clearance than a shaved Sals, and a Sals CWP can't be beaten for strength.
    NSW far north coast
    Quote Originally Posted by Summiitt View Post
    yep, wasn't the transition point '02 ?
    Jul 2008
    Hi
    On P38 Puma rear diffs, how many people have broken their CW&P? not half-shafts. If so what size tyres and how hard where you/they driving?
    I have a 130 that I use for touring running stock 235/85 tyres and don't want to put a Salisbury under it.
    I'm considering running a pegged Ashcroft P38 locker & their halfshafts.
    I'm not arguing about the Salisbury being much stronger - it is - fullstop anyone who has plucked out a center will know this. I have a shaved Sals with 35 spline 1.5" halfshafts and it is bombproof, but that under a 36" tyred playtruck.
    I just want a safe reliable touring solution for normal 4wd driving on stock tyres.
    Clive
    Sep 2013
    toowoomba
    The Misadventure 4wd crew (youtube it) blew the rear diff up in their SVX, crown wheel and pinion failure. Pretty sure they were running 265/75r16 Cooper at's at the time
    NSW far north coast
    Do Ashcroft's still make the P38 hypoid conversion ?
    Cant find it on the website, but that doesn't mean it isn't available.
