Results 1 to 4 of 4
Thread: Front end shudder
    Nov 2015
    Front end shudder
    Okay so my old girl has an intermittent shudder under brakes. It only occurs at speeds over 80km/hr. Think idiot in a patrol cutting across 4 lanes of a freeway and you grabbing the anchors and the horn at the same time.
    I have done all the obvious suspects.
    Steering assembly, tie Arms, Bushes, pan handle however the shudder persists. hoping someone here has had similar in the past and can point me to what I need to change / fix. The 110 does have 2"lift but that is about 4 years old and the springs etc still look good and no issues around them.
    Looking forward to the fonts of wisdom that will follow
    May 2008
    cairns
    Take out shims in your king pin /swivel bearing at the top
    Nov 2015
    sadly still there
    If it's under brakes then look there. Usually shudder indicates warped discs. You should also be able to feel it through the pedal.
