Results 1 to 10 of 17
Thread: 2014 Defender Rover Diffs
    Aug 2011
    MoveLater2 2014 Defender Rover Diffs
    G'day AULROIANS since we are all sitting around this campfire thought i'd ask a few questions, I've done a little reading on here & some suppliers web pages on differential bits & pieces now i've confused myself even more than when I started.
    Differential Pegging, can this be done to STD Rover differentials or only to Diff Locked differentials EG: Harrop/Eaton mainly.
    What goodies are a must need to change a STD 2014 front Rover differential from a grease type to oil lubricated type.
    Same question but for the 2014 Rover rear differential.
    The front Rover differentials have more parts to it than the rear Rover differential (CV joints ect.) anyway, What is the spline count on a STD 2014 Rover differential for the front & rear half shafts or put another way differential internals and drive flanges.
    From what i've read Harrop/Eaton Diff locks require 24 spline axels, and Ashcroft half shafts are 23 spline, have I maybe misread something. Is an axel a half shaft.
    Is a stronger/stretchy half shaft a must requirement when using a front or rear Diff lock or just preferred incase of heavy right foot at times.
    The same question for about HD flanges, must have or just nice incase not so skilled and heavy footed.
    I'm sure i'v read here long ago someone on here doesn't use HD shafts and flanges with there Lockers but maybe I just didn't understand what I was reading way back then too
    Thanks for helping clear up my confusion Regards.
    Safety Bay
    What mods you need comes down to want type of person you are,99% of people go through their whole life driving the interior not needing anything more than axle flanges and extra fuel capacity,the other 1% can't drive around the block without blowing a diff,I'm the former and I have a good mate who is the later.Common sense will get you further than pegged diff's and 35'' tyres. Pat
    Jun 2013
    What PAT303 says, plus a question: What are you going to be asking of your 2014 Defender?
    Just a daily driver around town? Occasional runs up the highway for chrissy holidays? Hard core trails? Just a little dirt road touring? Or a lot? Prep for the zombie apocalypse?
    Neil
    (Really shouldn't be a...) Grumpy old fart!
    MY2025.5 110 D250 S MHEV (L663)
    In Memoriam:
    MY2013 110 TDCi DCPU purchased new from Land Rover Malaysia in May 2013.
    ...traded in for the above L663 in December 2025.
    Nulla tenaci invia est via
    Aug 2011
    Arrow HARD TRACKS
    Quote Originally Posted by tact View Post
    tact. Usage on 4WD parks, free parks & tracks that see the use of full articulation & more so hard tracks ATM so with loss of forward momentum at times is seeing the need for at least a rear Diff Lock in the future.
    My driving style is slow & steady rather than a bull at a gate (not right foot heavy).
    I guess the plan for trips away is a given too so larger trips.
    Zombie Prep'er i'm not
    Bacchus Marsh Vic.
    I've recently looked at what the difference is between standard and heavy duty factory suspension.
    From what I could find...
    Same main differential housings,
    Same swivel housings,
    Same stub axles,
    I need to check the numbers for the crown wheel and pinion but suspect they are the same too,
    Same axles, flanges, wheel bearings,
    Different carrier-2 pin Std>4 pin HD
    Heavy duty also has a strengthening gusset on the chassis.
    The also ran heavier springs and steel rims.
    I'm gearing for dirt/remote touring towing with playing ability as it suits, so here is the aim...
    For me I'm going to loose the 2 pin carrier and go to ATB's as the budget allows.
    I'll keep the original axles and drive flanges as the ATB's are gentler on them than full lockers.
    If I strip a drive flange it's an easy job tracks side, the aim is this will be the weak point.
    I have retained the greased hubs and have converted to the 2 nut wheel bearing retainers instead of the 1 nut system.
    I'm fitting a ATB to transfer box in January as I consider it also a weak spot.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Safety Bay
    Quote Originally Posted by Rickoz View Post
    You already have traction control so a rear ATB is the go,quite a few have them and are very happy with them,best thing is they work on road just as well off,diff locks are off road only. Pat
    Aug 2011
    Arrow HARD TRACKS
    Quote Originally Posted by PAT303 View Post
    Thanks Pat after reading many Lockers Vs other options just like this one Locker vs LSD in the front. a locker is the only option if your lifting wheels off the ground, ta.
    Jun 2008
    Drouin East, Vic
    To answer your question about pegging, it can be done to a standard diff. The part that gets turned off the diff is the outer part of the flange on which the crownwheel is mounted, reducing the diameter to just outside the crownwheel bolt circle. The bronze pad runs on the now-exposed back face of the crownwheel. So all this is outboard of the actual workings of the diff itself, thus doesn't matter what is in the diff centre.
    I did my own when I installed an Ashcroft locker; I would not recommend doing it without the use of a milling machine to ensure accuracy.
    Aug 2011
    Thumbs up PEGGING
    Quote Originally Posted by POD View Post
    Thank you for that POD. My thoughts are Peg the front Differential and Diff Lock on the rear.
    Kingston, Tassie, OZ.
    My experience with these has been that if there is no noises early on, like up to 30000 km or so then they generally last ok. Have 1 puma 130 that has done 240k now and finally needs a pinion seal. They may be a stupid idea but some of them do last ok !
