Results 1 to 10 of 13
Thread: 2 Inch Lift kit vibration
    Sep 2012
    Perth Australia
    I have a two inch lift and just started to notice a vibration at 70kph and above accentuated under acceleration on standard height. The vibration disapeered when I lowered to highway height. I suspected uni joints.
    On inspection I could not find any movement in the uni joints. Anybody had a similar experience? I will be ordering a few spares.
    Paul
    Is it related to propshaft angles being excessive when lifted?
    Sep 2012
    Perth Australia
    Yes p38arover that is my belief
    Feb 2010
    Townsville, QLD
    I agree with Ron. Did the front shaft uni's on mine and mine disappeared.
    I used highway height for normal driving from then on.
    Keithy
    Sep 2012
    Perth Australia
    Thanks Keithy,
    I will order, replace the fronts and keep some spares.
    Jan 2012
    Bendigo
    Hammer, I had exactly the same issue on mine.
    The rear uni on the front shaft was tight, but was binding at the increased angles.
    Sent from my SM-G900I using AULRO mobile app
    Sep 2012
    Perth Australia
    Thanks Benji,
    That helps narrow the offending uni down. Looking at the uni joints connected to the front and rear diffs, I'd think as the vehicle is lifted the diffs rotate which would mantain to a degree the prop angles, where as the uni joints connected to the gearbox would increase thier angles. With the front prop being shorter the angle for the front uni to the gearbox would be greater. That makes sense. Please correct me if that's wrong.
    Feb 2010
    Townsville, QLD
    Yep, the uni on the front shaft at the transfer case was my culprit.
    Feb 2012
    Carnegie
    Must get around to replacing my uni's. I have the full set (plush the flexi joint for the rear) sitting in the garage. The front prop shaft should always have been a double cardan joint.
    Douglas Park, NSW
    Quote Originally Posted by davidsonsm View Post
    Does your car have the Rotoflex coupling? I know the parts catalogue shows some P38s having it but I haven't seen one on a Australian delivered car.
