Results 1 to 10 of 15
Thread: Shock absorbers for Classic on AIR
    Gosnells
    Its that time again.
    Sarah has been looked over for a 'wriggle' in the suspension.
    Initial diagnosis is 'Shocking shockers'.
    They're OEM "normal" replacements from a local LR dealer, 5 years / 100K ago.
    -Am getting a second opinion on that, but in the mean time... are Bilsteins a good value alternative to whatever is 'OEM' ?
    The originals were changed out at 135K, these are the First Replacements the car has had.
    My driving is strictly road, sealed/gravel. NO rock-hopping or bush bashing etc. No towing.
    Worthwhile buying from the UK, or does the carriage make it uneconomical?
    Looks like I'll be keeping her for another 5 years...
    james in Gosnells
    The Lady Sarah, 1995 Vague SE with working air suspension...
    South Sydney
    James, I would be very hesitant to use aftermarket shocks, even Bilstein or Koni as it will noticeably change what is a superbly smooth suspension.
    If you do replace with OEM, make sure they are to genuine quality... and suit EAS. Don't buy Britpart or Allmakes/Bearmach.
    Talk to either Bilstein or Koni head office if you want to go aftermarket, and make sure what they are selling you suits air springs, as the factory dampers are not charged, they are an old school hydraulic shock (do not expand on their own).
    I'd be looking to Koni as they make shocks like this...
    Oct 2011
    Fremantle WA
    James, for what it is worth, Bessie has adjustable Konis per PO, and I don't think they were all that expensive (relatively speaking of course).
    May 2006
    Woolgoolga
    Have read the koni's work quite well with eas, and that the bilsteins are a bit harsh
    Gosnells
    ...From a quick look at the Usual Suspects, the best price from Blighty ... about $180 for a pair... "aftermarket".
    Ouch!
    The Bilsteins were recommended by the mechanic... He does a lot of modifying/beefing up of Deefers etc, so I guess he's biased towards "performance".
    - I'm only after Comfort
    Oct 2011
    Fremantle WA
    Pillows then sir?
    South Sydney
    That's very cheap! lol!
    Bilstein do comfort too... but I'd look to Koni first.
    Nov 2015
    Black Rock
    I installed a set of Koni reds (adjustable and designed for EAS) years ago (probably ten or more) and they are still excellent. Driving is both road and off-road, probably about 100,000kms. They are adjustable so that as they wear, you can tighten them back up to spec. I tried this a few years ago, but it turned out that they were still on spec so I returned them to standard plus half a turn. They have stayed this way ever since. Could probably do with another half turn now. From memory, I think you have five full turns of adjustment.
    For off road use, it is important to replace the rubbers every now and again. I've done this once and it's probably time to do it again.
    FYI I have an LSE with EAS and with standard size tyres.
    Last edited by DieselLSE; 20th December 2015 at 02:25 PM. Reason: Updated with pic
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Oct 2011
    Sunshine Coast
    For what it's worth I contacted paddocks for some Bilsteins they wouldn't sell them as they were not allowed to freight them due to Nitrogen charge. They have to go sea freight which they weren't prepared to do.
    Jan 2012
    Bendigo
    I've had the konis on my 93 with eas.
    I think they are brilliant. They're firmer than stock, but the back end will still float.
    If you swerve though, the shocks will feel very firm.
    I had bilstein before that. They were very firm, but that didn't really translate into better handling.
    Sent from my SM-G900I using AULRO mobile app
