Thread: cable(s) thru firewall
    May 2006
    Ulverstone,TAS
    Am wishing to put a couple of cables through the firewall.
    1) uhf lead
    2) engine temp gauge cable.
    Which side would be the better, drivers or passenger side.
    Any other helpful hints greatly appreciated.
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Jan 2015
    Mt. Eliza
    Not sure, but if it helps I bought a couple of various sized cable glands from Bunnings for under $2 each. Make a nice smooth point to pull cables through once you've drilled a hole in the firewall (if required).
    Aug 2010
    Sunbury, VIC
    I ran the antenna lead for my UHF up the passenger side, then in through the firewall behind the battery. You will need to prop the bonnet right up and remove the battery, but once you do that, it's pretty easy. I used an existing rubber boot that had a bunch of wire in it - I just punched a small hole through the rubber lip above where the existing cables ran with a Phillips head screwdriver. This ensure no rubbing of the cable, and stays dust tight. On the inside, remove the glovebox (I think that was all) to retrieve the cable inside the cabin area.
    Feb 2014
    As above, L/H side, large flexible gromet will see a couple extra cables squeezed thru
    Aug 2013
    Howrah, Tas
    Hi l ran my extra uhf and engine temp electrical cable through the drivers grommet above the brake booster.
    Sent from my GT-I9505 using AULRO mobile app
    Jason
    Range rover l322 2002 TD6
