Results 1 to 10 of 20
Thread: Bog out
    Feb 2013
    Ballarat,Vic,Aus
    Bog out
    This is quite smart..
    Welcome to Bog Out Vehicle Recovery Device
    Cant' say I'd want to roll them up and put back into the car after using in a bog hole ..... but still. I can't see why it wouldn't work
    [ame]https://youtu.be/MoofMb2pnGI[/ame]
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yeah, but what if you have no traction on the other wheel? If you don't have a diff lock, then that one just starts spinning, so I think in a lot of situations you would need to do it to both wheels.
    Jun 2010
    Central Coast NSW
    Thats a pretty cool idea. Its a good $600 to get two 4.5m straps plus two 30m ropes tho.
    Better than something like maxtrax?
    Dan
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by bacicat View Post
    You have to do both wheels.... So it would be slowish to setup as you need to setup both wheels on whichever axle your using. It's probably easier to carry a tirfor, but still, nifty idea
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Adelaide Hills - SA
    That's pretty good - as long as you have something to tie it on to.
    Simple idea. You could make a set at home with some seatbelt webbing and a sewing machine without too much trouble!
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    So how to get it off with out driving back in to the bog again? It has to be unwound again to get it off.
    Or am I over thinking the problem (again (or should that be still))?
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by austastar View Post
    Hi,
    Good point. looks like you have to jack up each wheel to get them off....
    Feb 2013
    Ballarat,Vic,Aus
    Just drive on them until you are out of the bog hole or past the obstacle ..... then drive backwards and they'll roll back out for you
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Adelaide Hills - SA
    But then you'd be back in the bog hole again...
    May 2008
    Bundaberg Qld
    Quote Originally Posted by spudboy View Post
    drive a bit further forward first
